Problems with starting No one survived
Windows 10
New install … brand new AMP … same problem with the other computer and install … started after an update…
[2024.03.05-23.55.56:204][ 0]LogMemory: Process Physical Memory: 236.39 MB used, 241.91 MB peak
[2024.03.05-23.55.56:204][ 0]LogMemory: Process Virtual Memory: 204.39 MB used, 204.39 MB peak
[2024.03.05-23.55.56:204][ 0]LogMemory: Physical Memory: 3773.08 MB used, 12502.89 MB free, 16275.97 MB total
[2024.03.05-23.55.56:204][ 0]LogMemory: Virtual Memory: 4403.44 MB used, 14816.53 MB free, 19219.97 MB total
00:56:02
[2024.03.05-23.56.02:411][ 6]LogSteamSocketsAPI: Warning: SteamSockets API: Warning SDR network config fetch first attempt failed. HTTP 504. . Trying again.
00:56:04
[2024.03.05-23.56.04:095][ 6]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Got SDR network config. Loaded revision 1700157702 OK
[2024.03.05-23.56.04:095][ 6]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Performing ping measurement
[2024.03.05-23.56.04:095][ 6]LogSteamSocketsAPI: Verbose: SteamSockets API: Log SDR RelayNetworkStatus: avail=Attempting config=OK anyrelay=Attempting (Performing ping measurement)
[2024.03.05-23.56.04:095][ 6]r.VolumetricCloud.DistanceToSampleMaxCount = “3.1”
[2024.03.05-23.56.04:095][ 6]r.VolumetricRenderTarget.Mode = “2”
[2024.03.05-23.56.04:096][ 6]r.EyeAdaptation.BlackHistogramBucketInfluence = “0.5”
[2024.03.05-23.56.04:120][ 6]net.UseAdaptiveNetUpdateFrequency = “1”
00:56:06
[2024.03.05-23.56.06:071][ 65]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Ping measurement completed
[2024.03.05-23.56.06:071][ 65]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Ping location: sto=3+0,sto2=3+0,hel=9+0/10+0,ams=23+2/22+0,waw=27+2/23+0,fra=25+2/25+0,lhr=28+2,par=36+3/31+0,vie=34+3/34+0,iad=92+9,sgp=261+26/206+15,gru=219+21
[2024.03.05-23.56.06:071][ 65]LogSteamSocketsAPI: Verbose: SteamSockets API: Log SDR RelayNetworkStatus: avail=OK config=OK anyrelay=OK (OK)
00:56:07
[2024.03.05-23.56.07:394][ 89]t.MaxFPS = “30”
00:56:11
[2024.03.05-23.56.11:060][200]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Gameserver logged on to Steam, assigned identity steamid:90190904058741761
[2024.03.05-23.56.11:060][200]LogSteamSocketsAPI: Verbose: SteamSockets API: Log AuthStatus (steamid:90190904058741761): Attempting (Requesting cert)
[2024.03.05-23.56.11:060][200]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Set SteamNetworkingSockets P2P_STUN_ServerList to ‘162.254.195.66:3478’ as per SteamNetworkingSocketsSerialized
[2024.03.05-23.56.11:329][208]LogSteamSocketsAPI: Verbose: SteamSockets API: Log AuthStatus (steamid:90190904058741761): OK (OK)
[2024.03.05-23.56.11:329][208]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Certificate expires in 48h00m at 1709855653 (current time 1709682852), will renew in 46h00m
cant get it to start…
We have exactly the same problem, have you found any solution yet?
Windows Server 2022
Fresh downloaded No One Survived Dedicated Server (Steam App-ID: 2329680)
Latest VC++ Redist (2015-2022) is installed (x86 and x64)
