Problems with license
OS Name/Version: UBUNTU SERVER 22.04
Product Name/Version: AMP Release “Halimede” v2.4.0.10, built 27/10/2022 18:15
Hello,
every time I launch the AMP interface,
I have this message popping up.
AMP has lost its licence key due to a hardware or system configuration change.
Please re-enter your licence key under Configuration -> New Instance Defaults.
You may also need to reactivate your existing instances on this host.
How can I fix this problem?
Knowing that
AMP is installed on a dedicated machine,
No docker
only one ethernet interface with static MAC and fixed IP.
Can appear randomly when I refresh the page http://192.168.1.12:8080/
enter the license under Configuration → New instance and restart instances.
What’s the output of ip addr ?
here is the output,
would IPv6 be the problem?
~$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s31f6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 4c:cc:6a:d7:01:7c brd ff:ff:ff:ff:ff:ff
inet 192.168.1.12/24 brd 192.168.1.255 scope global enp0s31f6
inet6 fd2a:a2c:3b67:0:4ecc:6aff:fed7:17c/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 1788sec preferred_lft 1788sec
inet6 2a02:8428:469e:df01:1:2:3:12/64 scope global
inet6 fe80::4ecc:6aff:fed7:17c/64 scope link
valid_lft forever preferred_lft forever.
I can confirm that it’s happening, AMP having issues with remembering passwords or other things.
when rebooting a server this usually happens.
About AMP Instance
  • OS Name/Version: ubuntu22.04.01
  • Product Name/Version: AMP Release: “Halimede” v2.4.0.10, built 27/10/2022 18:15
Error
