Problems upgrading to 2.4.4.0
OS Name/Version: Ubuntu 22.04.3 LTS
Product Name/Version: AMP Instance Manager v2.4.1.2 built 21/12/2022 17:55
I am trying to upgrade to version 2.4.4.0 via the command line. usually i just do the following
sudo su -l AMP
ampinstmgr -p
but when i do that this time i get the following error below.
[/home/AMP/.ampdata/instances/AMPCache-Mainline-2440.zip]
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
ampinstmgr -p
[Info] AMP Instance Manager v2.4.1.2 built 21/12/2022 17:55
[Info] Upgrading instance ADS01
[Info] Using cached archive: /home/AMP/.ampdata/instances/AMPCache-Mainline-2440.zip
[/home/AMP/.ampdata/instances/AMPCache-Mainline-2440.zip.ZIP]
[Error] Download or unpack failed. Please check your network connection and try again.
[Error] Unzip return code was 2
[Info] Upgrade failed
the box is up to date and rebooted and I even tried deleting all the AMP cache files and letting it redownload the 2.4.4.0 version which it did but still the same error.
2.4.4.0 is long out of date, are you absolutely certain that your system is up to date? An update to ampinstmgr (usually handled via apt) is required to pull versions 2.4.5 and beyond.
If so, do you see the cubecoders repo when you run an apt update?
Its possible that you may have either removed the repo (such as during an OS upgrade) or are still using the expired key. Posting the output of an apt update will let us confirm that.
you are correct the repository got disabled and doesn’t seem to work after an LTS upgrade it looks. I deleted the repo and tried to re-run the install script but it doesn’t seem to add the repo. how can this be manually added? or what is the best way to fix this.
If its just disabled but still present, you may need to reenable it rather than readding it, but try giving bash <(wget -qO- getamp.sh) addRepo a go
