Problem with my license
OS Name/Version: Windows 11 24H2 build 26100.3194
Product Name/Version: 2.6.0.12 - 20250224.1
I upgraded my AMP license with the command: ampinstmgr reactivateall.
The problem is that when I create a new instance, I have to run the command again, otherwise my instance won't have a license.
  • Step 1 : Activate AMP with the AMP Professional Edition license
  • Step 2 : Activate a new AMP Advanced Edition license with the command: ampinstmgr reactivateall
Reactivate the license with the command: ampinstmgr reactivateall
Make sure you enter the new licence in the main panel’s settings under Licence Key
Can you tell me which panel you are talking about?
The AMP web panel, the same place you manage your instances from
