OS = AlmaLinux release 8.6 (Sky Tiger)
Running AMP Ver 2.3.4.0
Trying to install ARK Survival Evolved from the “Create Instance” button fails
- Select Application: ARK: Survival Evolved
- Friendly name: ARK
- After Creation: Start Instance
- Click on “Create Instance”
All appears ok and the status says “Running”. Double click the instance, and I get the status page that shows a “Start” and “Update” button. Pressing “Start” button causes the message “ARK could not be installed”. Also, a spinning progress pops up on the top right saying “Application State: Unable to run”.
I tried the “Update” button with the same result.
Prior to all of the above, I performd a “yum update” and upgraded AMP (it was already on 2.3.4.0 so no change there).
I stopped and restarted the instance and again, no change.
I looked through all of the ARK options in AMP and couldnt see anything wrong.
I’m running AMP direct (ie not under docker).
Do you have any suggestions on what might be going wrong ?
