Problem for runing server
OS Name/Version: Ubuntu 20.04
Product Name/Version: Rust Server Version 1.62.0
does AMP work with ARM architecture? Because I am not able to run any server.
If you’re sharing console output, logs, or commands you have run, please make sure to use code tags
provides syntax highlighting.
Log server:
Error loading needed lib libsqlite3.so.0
Warning: Cannot dlopen(“libsqlite3.so.0”/0xaf8e9190, 101)
Error loading needed lib /home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Mono/libsqlite3.so.0
Warning: Cannot dlopen("/home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Mono/libsqlite3.so.0"/0xfffd46ef32c0, 2)
Fallback handler could not load library /home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Mono/libsqlite3.so.0
Error loading needed lib libsqlite3.so.0.so
Warning: Cannot dlopen(“libsqlite3.so.0.so”/0xaf8e9190, 101)
Error loading needed lib /home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Mono/libsqlite3.so.0.so
Warning: Cannot dlopen("/home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Mono/libsqlite3.so.0.so"/0xfffd46ef32c0, 2)
Fallback handler could not load library /home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Mono/libsqlite3.so.0.so
Warning: Cannot dlopen(“libsqlite3.so.0”/0xaf761470, 101)
Error loading needed lib /home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Managed/libsqlite3.so.0
Warning: Cannot dlopen("/home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Managed/libsqlite3.so.0"/0xaf74bc00, 101)
Error loading needed lib /home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Managed/libsqlite3.so.0.so
Warning: Cannot dlopen("/home/amp/.ampdata/instances/rust/./rust/258550/RustDedicated_Data/Managed/libsqlite3.so.0.so"/0xaf74bc00, 101)
Error loading needed lib /home/amp/.ampdata/instances/rust/rust/lib/libsqlite3.so.0
Warning: Cannot dlopen("/home/amp/.ampdata/instances/rust/rust/lib/libsqlite3.so.0"/0xaf8f03f0, 101)
Error loading needed lib /home/amp/.ampdata/instances/rust/rust/lib/libsqlite3.so.0.so
Warning: Cannot dlopen("/home/amp/.ampdata/instances/rust/rust/lib/libsqlite3.so.0.so"/0xaf8f03f0, 101)
Warning: Cannot dlopen(“libsqlite3.so.0”/0xaf8f0260, 101)
Warning: Cannot dlopen(“libsqlite3.so.0.so”/0xaf8f0260, 101)
Warning: Cannot dlopen(“libsqlite3.so.0”/0xaf761360, 101)
DllNotFoundException: libsqlite3.so.0
at (wrapper managed-to-native) Facepunch.Sqlite.Interop.sqlite3_open(string,intptr&)
at Facepunch.Sqlite.Database.Open (System.String path, System.Boolean fastMode) [0x00013] in <76e846659a69415eb4892b414ec2b783>:0
at UserPersistance…ctor (System.String strFolder) [0x0003d] in :0
at ServerMgr.Initialize (System.Boolean loadSave, System.String saveFile, System.Boolean allowOutOfDateSaves, System.Boolean skipInitialSpawn) [0x00006] in :0
at Bootstrap+d__19.MoveNext () [0x002fb] in :0
at UnityEngine.SetupCoroutine.InvokeMoveNext (System.Collections.IEnumerator enumerator, System.IntPtr returnValueAddress) [0x00026] in <0b31faaf1c50461d95c83ac166a20393>:0
(Filename: <76e846659a69415eb4892b414ec2b783> Line: 0)
Ports Details:
[Info] Port usage for rust (rust)
[Info] Instance is currently running.
[Info] LISTENING 8081 TCP (Core.Webserver.Port)
[Info] LISTENING 2224 TCP (FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] CLOSED 28015 UDP (RustModule.Rust.Port)
[Info] CLOSED 5678 TCP (RustModule.Rust.RconPort)
[Info] CLOSED 28082 TCP (RustModule.Rust.AppPlusPort)
  • Accessing the web panel and starting the instance
I tried to create other types of servers, but without success.
AMP runs on ARM but most game servers don’t, even with the emulation layer.
Minecraft works, so does Valheim and a couple of others. But it’s extremely hit and miss.
I plan on playing with ARM support more after the config gen is “done” and a couple game servers are added. I think we can get more games supported with some tweaking, but definitely no guarantees.
Thanks guys.
Is there somewhere I can be following?
Mostly in the Discord where I’m more active and just gossip about what I’m playing with. Lol Mike usually puts in release notes if there are major updates like new support on a platform.
