OS Name/Version: Windows 10
2.4.0.4 -
Problem Description: Instance does not start, port becomes in use by amp. restart of instance throws port usage error
ADS01 Logs
12:22:12
Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
ADSModule requests dependency InstanceManagerPlugin...
12:22:13
Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
ADSModule requests dependency SystemUserManagerPlugin...
Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
12:22:14
Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
Using keypair with fingerprint ZXdwl3gBVB3Rb66jeMRvq/r62+g7ijoxN5H6Cp50O/Q=
Websockets are enabled.
12:22:15
RouterTimer@10Hz with 2 jobs started
Checking for AMP updates...
fatal: detected dubious ownership in repository at 'D:/AMPDatastore/Instances/ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates'
'D:/AMPDatastore/Instances/ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates' is on a file system that doesnot record ownership
To add an exception for this directory, call:
git config --global --add safe.directory D:/AMPDatastore/Instances/ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates
AMP is up-to-date.
:admin12:22:26
Waiting for AMP instance to start...
12:22:31
Instance status is offline but process has not exited...
12:22:56
Downloaded file __VDS__mained01/AMP_Logs/AMPLOG 2022-09-14 16-22-27.log (API mode)
12:23:05
Uploaded file __VDS__mained01/AMP_Logs/AMPLOG 2022-09-14 16-22-27.log (API mode)
12:23:11
Upgrading instance mained01
12:23:12
Using cached archive: D:\AMPDatastore\Instances\AMPCache-2404.zip
12:23:23
12:23:28
Failed to start AMP. Exit code was -2146232797
12:25:05
Changing setting ADSModule.Networking.DefaultAppIPBinding to 0.0.0.0
12:25:10
12:25:11
12:25:22
12:25:27
12:25:59
Changing setting ADSModule.Networking.DefaultAppIPBinding to 10.0.0.185
12:28:15
12:28:20
12:28:32
12:28:36
12:28:41
- MC INSTANCE INITIAL LAUNCH
[16:22:27] [Program Info] : Starting AMP version 2.4.0.4 (Halimede), built 10/09/2022 16:30
[16:22:27] [Program Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[16:22:27] [Core Warning] : Current time zone is set to Eastern Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[16:22:27] [Program Info] : OS: Windows / x86_64
[16:22:27] [Program Info] : CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz (4C/4T)
[16:22:27] [Program Info] : AMP Instance ID: d7d99d50-4959-4798-a37f-bb0a19064e0f
[16:22:28] [Core Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[16:22:28] [Core Info] : Metrics publishing is enabled at udp://127.0.0.1:12820.
[16:22:28] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[16:22:28] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[16:22:28] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[16:22:28] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[16:22:28] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[16:22:28] [Core Info] : Licence Present: AMP Professional Edition (Licenced to William Tober)
[16:22:28] [FileManager Notice] : Using keypair with fingerprint w6ZNw4ggXlA/by1HoylnG5vWgEY2csdmBVRjXXDL5BA=
[16:22:28] [ModuleLoader Info] : SFTP Server started on 10.0.0.185:2229
[16:22:28] [WebServer Info] : Websockets are enabled.
[16:22:29] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[16:22:29] [Core Info] : Webserver started on http://0.0.0.0:8101
[16:22:29] [System Info] : Checking for AMP updates...
[16:22:29] [System Info] : AMP is up-to-date.
[16:22:32] [System Info] : Modpack cache is up-to-date.
- MC INSTANCE LOGS AFTER INITIAL LAUNCH ATTEMPT
[16:28:37] [Program Info] : Starting AMP version 2.4.0.4 (Halimede), built 10/09/2022 16:30
[16:28:37] [Program Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[16:28:37] [Core Warning] : Current time zone is set to Eastern Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[16:28:37] [Program Info] : OS: Windows / x86_64
[16:28:37] [Program Info] : CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz (4C/4T)
[16:28:37] [Program Info] : AMP Instance ID: d7d99d50-4959-4798-a37f-bb0a19064e0f
[16:28:38] [Core Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[16:28:38] [Core Info] : Metrics publishing is enabled at udp://127.0.0.1:12820.
[16:28:38] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[16:28:38] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[16:28:38] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[16:28:38] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[16:28:38] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[16:28:38] [Core Info] : Licence Present: AMP Professional Edition (Licenced to William Tober)
[16:28:38] [ModuleLoader Error] : Unable to start SFTP server.
[16:28:38] [FileManager Error] : InvalidOperationException
[16:28:38] [FileManager Error] : [0] (InvalidOperationException) : The specified socket is already in use.
[16:28:38] [FileManager Error] : at tyfsv.rsrrj.vfuno(EndPoint p0, Boolean p1)
at tyfsv.rsrrj..ctor(EndPoint ep, String hostname, mnbpk runner)
at Rebex.Net.Servers.Core.Server.Bind(IPEndPoint endPoint, ServerModule module)
at FileManagerPlugin.PluginMain.PostInit()
[16:28:38] [FileManager Error] : SocketException
[16:28:38] [FileManager Error] : [1] (SocketException) : Only one usage of each socket address (protocol/network address/port) is normally permitted
[16:28:38] [FileManager Error] : at Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at Net.Sockets.Socket.Bind(EndPoint localEP)
[16:28:38] [WebServer Info] : Websockets are enabled.
[16:28:38] [Core Info] : Webserver started on http://0.0.0.0:8101
[16:28:38] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[16:28:38] [System Error] : Socket exception - Trivial error / user error. Will not be submitted.
[16:28:38] [System Error] : [Error] --- Begin Exception Data ---
[Error] OS: Windows (x86_64/None)
[Error] Module: MinecraftModule, Version: AMP 2.4.0.4
[Error] Release spec: Release - built by CUBECODERS/buildbot on CCL-DEV
[Error] Instance ID: d7d99d50-4959-4798-a37f-bb0a19064e0f
[Error] SocketException
[Error] [0] (SocketException) : Only one usage of each socket address (protocol/network address/port) is normally permitted
[Error] at Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at Net.Sockets.TcpListener.Start(Int32 backlog)
at m.Http.HttpBackend.ConnectionLoop()
[16:28:38] [ErrorReporter Info] : ####################################
[16:28:38] [ErrorReporter Info] : # Self Diagnostics #
[16:28:38] [ErrorReporter Info] : The IP and Port combination requested by the socket is already in use by another application. Either end the other application or re-bind this AMP instance to a different IP/port.
[16:28:38] [System Info] : Checking for AMP updates...
[16:28:39] [System Info] : AMP is up-to-date.
- Step 1 : Start ADS01, Start Minecraft Instance, it fails but gives dubious error code -2146232797
- Step 2 : Attempt to restart the instance. No error is given but the MC Instance Logs states that the port is now in use, this can be confirmed in windows resource manager.
- Step 3 : Smack head on table
Not sure yet, it’s early and not enough caffeine. Might just manually launch my instances and skip amp until I feel like messing with it.
