Port forwarding?
OS Name/Version: Ubuntu 24.04.2 LTS
Product Name/Version: 2.6.1.4 - 20250410.2
Problem Description: I have set up a AMP server using Ubuntu and is able to connect using play.gg, but I want to go the next step in port forwarding. I can’t find any information on how to port forward.
Note I have two machines, my main desktop for games and another machine with ubuntu.
I’m using a ASUS AC66U with external ports 25565:2556, internal IP(ubuntu machine) 192.168.XX.XX with protocol Both(UDP/TCP). On AMP panel Primary Endpoint 192.168.XX.XX:25566 and Game Port 25566 Both. But my friends are still unable to connect. Am I doing something wrong?
Double-check that port forward for typos, as you write 2556 there.
When getting your friends to connect give them your public IP (google “what is my IP” to get it).
You can also use this site to check if the port forwards are working:
https://mcsrvstat.us/
