Port Forwarding troubleshooting guide
Unable to Join Server or server not visible – Simple Troubleshooting Guide
Before starting:
  • Make sure the game server is running in AMP
  • Make sure you are using the correct server IP and port
  • Verify the server is listening on the correct protocol:
    • TCP
    • UDP
    • or both TCP & UDP
1. Check Your Public IP Windows
Open in browser:
myip.is
Check Public IP Linux
Run:
curl -4 -s https://api.ipify.org
2. Configure Port Forwarding
In your router:
  • Forward the game server port to the local IP address of the machine running the server
  • Use the correct protocol:
    • TCP
    • UDP
    • or TCP & UDP
Example:
  • Server PC local IP: 192.168.1.50
  • Game port: 27015
Forward:
27015 → 192.168.1.50
3. TCP Port Testing
TCP ports are easy to test because they return a response.
Test Steps
Open:
https://dnschecker.org/port-scanner.php
Enter:
  • Your public IP
  • Your TCP port
Press:
Check
Expected Result
You should see:
Open
If you see anything else:
  • Port forwarding is incorrect
  • Firewall is blocking the port
  • Server is not running
  • ISP may be blocking the port (CGNAT etc, very possible situation if you have never hosted anything ever)
4. UDP Port Testing
UDP ports are harder to test because they usually do not respond directly.
Recommended UDP Testing Method (Linux)
The best way to test UDP is monitoring incoming packets directly on the server.
Install tcpdump
sudo apt install tcpdump
Monitor UDP Traffic
sudo tcpdump -i any udp port YOUR_PORT
Example:
sudo tcpdump -i any udp port 27015
When that command is running open tool like:
Enter in to it your public IP and UDP port and press Scan Now.
Result
If port forwarding works, you will see incoming UDP packets in the terminal.
If nothing appears:
  • Firewall is blocking traffic
  • Server is not listening on the port
5. Firewall Checks
Only do these checks if the port tests above fail.
Windows Server
Windows Firewall Testing
Temporarily disable Windows Firewall and test again.
If it works afterward:
  • Create a proper firewall rule
  • Re-enable the firewall
Linux Server
Firewall Checks
Make sure firewall tools are not blocking the port and disable temporarily if required. Test again. (Personally these have not caused any issue to me so far)
  • ufw
  • firewalld
  • iptables
Example for UFW:
sudo ufw status
