Permission errors ark INSTANCE
OS Name/Version:Ubuntu 22.04
Product Name/Version: (Always use the full version number - not ‘Latest’) 2.4.7
I copied my ark BACKUP files and moved them to the directory today and now i cant start my ark instance
AMP was unable to start the application. Possible causes may include insufficient permissions to load the executable, or the file not being correctly flagged as being an executable file. Check AMPs logs for more information.
  • Step 1 copy ark Shootergame files to ark server
  • step 2 press start
none im clueless, i literally switched from windows to linux bc on amp windows id get permission errors after i moved my saved from another server, im out of ideas.
How did you copy them? If you didn’t do so correctly then the permissions are wrong.
through another file manager client, i copied the entire shootergame into there.
