PC needing restart after not being in use for a shot period
i made a minecraft server a little while ago but i have to manually turn the PC its running on off and then back on for AMP to connect to it. is there any way to change the power settings so i can just leave the server on all the time? thanks.
Not sure what you mean is happening. Maybe you’re dealing with the Minecraft sleep mode which can be disabled within the instance?
