Pavlov VR has the following requirements:
- Dependencies need to be installed. They are listed here: http://wiki.pavlov-vr.com/index.php?title=Dedicated_server#System_setup_and_software_installation
- Ports 8177-8277 and 9100-9200 should not be excluded in the Application Port Ranges under Configuration->New Instance Defaults (AMP includes all but a few by default, so this is only relevant if you edited your setup or upgraded from older versions.)
- Application Port 2 needs to be 400 above Application Port 1
(Credit to @Greelan)
