Path of Titans - Webhooks & Game.ini
Hello,
TL;DR
Every time I stop the server, add my webhooks to the Game.ini file for discord, and boot the server back up the entire webhook section is gone. I’ve tried through SFTP and through the editor in AMP while having both the game server shutdown and also the entire instance shutdown.
Also
I’ve already tried the solution, posted by Ashlyne, that resolved someone’s ARK Game.ini issue.
[ARK Game.ini getting overwritten with blank file]
if you want to manually edit a file that amp uses:
  1. Stop the instance
  2. edit the file
  3. Start the instance
See if this fixes your issue
The long of it…
I got my server up and running just fine, all the mods are working as they should, the admins roles are working, but the Discord webhook section in Game.ini is completely broken. I assume this is due to AMP clearing the modified section of the Game.ini file on boot?
This is somewhat of an issue as I want the moderators of the server to be able to see what actions are happening in game without giving them access to my AMP installation.
Is there any work around for this? Or is there anyway to get a hotfix that allows me to add the “[ServerWebhooks]” section, and associated entries, to the file without it getting cleared out on server startup? A UI section for this, and to add new dinosaur mods, would be nice.
Thanks so much!
p.s.
I love AMP!
