Palworld showing Application Error
OS Name/Version: Unraid 6.12.14 Docker ( mitchtalmadge/amp-dockerized)
Product Name/Version: v2.6.0.6, built 20/11/2024 20:57
Problem Description: Palworld server showing errors, but still running. Server is up and reachable for multiple users, but AMP is showing that it is offline. I cannot run commands from the console, I have to use RCON to run commands. Resources will also show 0% usage. This does not happen on other game servers.
  1. Create Palworld Server
  2. Start server then reboot
  3. Server provides errors on each reboot
Actions taken to resolve so far: Initially I thought it was my save file, but I’ve tried recreating the instance multiple times, and the issue persists even with new fresh installs. It will launch perfectly the first time, but after a reboot it will give this error and will continue to run.
The Unraid Docker container is not a supported setup
