Palworld - PalWorldSettings.ini Empty on every run
OS Name/Version: ubuntu 22.04
Product Name/Version: AMP Release “Decadeus”
v2.4.8, built 29/01/2024 18:40
Problem Description: Every Time I launch only the palworldsettings are empty our changes to engine.ini do persist though, both windows and linux configs are empty btw not just linux
Im actually not sure seems to be the last 5.1.1 update
create a new instance, run in docker, readd config, removed custom args
i tried updating the github to add spaces between args but that doesnt work, convert save to json and back. updating the instance, moving save to new instance.
as a bandaid: For now we used a worldoptions file to change settings but we dont have many options and it stops reading the engine.ini which is where we made changes to smooth out gameplay. but worldoptions.save does let us change the config.
EDIT: when we noticed this issue was happening, we also found when we hit start it launched 6 servers. we stopped the server in the instance and the original one was still running i stayed connected until we stopped the whole instance
