On port does not open
OS Name/Version: Windows
Product Name/Version: AMP Release “Decadeus” v2.4.7, built 09/01/2024 03:40
SFTP Port 2224 TCP is open
Game Port 19132 UDP is closed
Query Port 27015 UDP is open
run as admin in powershell on computer running AMP
New-NetFirewallRule -DisplayName “IcarusServer - TCP 19132” -Direction Inbound -Protocol TCP -LocalPort 19132 -Action Allow
New-NetFirewallRule -DisplayName “IcarusServer - UDP 19132” -Direction Inbound -Protocol UDP -LocalPort 19132 -Action Allow
on my firewall (bit defender) AMP.exe, AMPService.exe and AMPinstmgr.exe are full open all port, everything is open
On my routeur RT-AC68U port forwading is ON and port 19132 is set for both UDP/TCP for the server IP like 27015 is
in PowerShell - ampinstmgr ports Icarus01
[Info] AMP Instance Manager v2.4.7 built 09/01/2024 03:41
[Info] Port usage for Icarus01 (Antiope)
[Info] Instance is currently running.
[Info] LISTENING 8081 TCP (Core.Webserver.Port)
[Info] CLOSED 19132 UDP (GenericModule.App.Ports.$GamePort)
[Info] LISTENING 27015 UDP (GenericModule.App.Ports.$QueryPort)
I dont know what to do more
Does the instance show its status and Running and accepting players?
Hi mike
Application state: running
memory usage is 1.43gb
Acrive users 0/8
Cpu usage 0%
Endpoint is 0. 0.0.0:19132
And what happens if you try connecting in-game?
I don’t see my server on the dedicated server list in game, but I have seen it once on the LAN tab
I trust the “friendly name” is the name to look for?
ALSO
I tried to update the ICarus game as there is a new patch like every friday, is this normal ?
10:07:03
10:07:12
Stopping instance Icarus01…
Requesting soft-stop…
Waiting for instance to stop…
10:07:33
Soft-stop request was ignored after waiting for 20 seconds, force stopping…
Instance Icarus01 has stopped
Instance Icarus01 has stopped.
10:07:38
LIM - Failure to make API call to Icarus01: An error occurred while sending the request.
Slow method invocation: Servers took 4057ms to complete.
Slow response: ADSModule.Servers took 4062ms to complete.
10:07:39
Slow method invocation: Servers took 4043ms to complete.
Slow response: ADSModule.Servers took 4048ms to complete.
Waiting for AMP instance to start…
AMP instance Icarus01 is now running.
10:07:40
Slow method invocation: Servers took 4034ms to complete.
Slow response: ADSModule.Servers took 4038ms to complete.
Slow method invocation: RefreshInstanceConfig took 36926ms to complete.
Slow response: ADSModule.RefreshInstanceConfig took 36933ms to complete.
Upgrading instance Icarus01
10:07:41
Slow method invocation: Servers took 4054ms to complete.
Slow response: ADSModule.Servers took 4059ms to complete.
10:07:42
Slow method invocation: Servers took 4053ms to complete.
Slow response: ADSModule.Servers took 4057ms to complete.
10:07:43
Slow method invocation: Servers took 4062ms to complete.
Slow response: ADSModule.Servers took 4066ms to complete.
10:07:44
Slow method invocation: Servers took 4061ms to complete.
Slow response: ADSModule.Servers took 4065ms to complete.
10:07:45
Slow method invocation: Servers took 2682ms to complete.
Slow response: ADSModule.Servers took 2692ms to complete.
Slow method invocation: Servers took 3728ms to complete.
Slow response: ADSModule.Servers took 3751ms to complete.
Thanks for helping
That’s the log from ADS, check the log of the actual instance.
