Notification of player logins for Bedrock server?
Hello! Newbie here. Just managed to get my server running.
Is there a way I can get notifications when someone logs in my Minecraft Bedrock server?
Yes, using the scheduler.
OK, thanks!
Could you please elaborate? Is there a guide on how to use the scheduler? I’m guessing this could be done with the send a message to discord option (or the others like pushbullet, etc). But I don’t know how to schedule this. I oculdn’t find a guide or a list of commands. Is there something like that? So I can learn and schedule more advanced tasks as well.
Add a trigger for someone joining, and then on that trigger add a task for a notification (such as Discord as you say) and fill in the fields. If you have a question about any of the fields, then we can answer that for you.
Thank you very much for the prompt reply. I ended up using AmpBot for Discord. It would be probably easier to use scheduler with webhooks but I’m such a noob I could not figure out how it works. (content and display name). The bot seems to work just fine though with some extra functionality.
