AMP Version 2.4.0.4
The locks show that my license is not recognized and therefore I can not make new instances.
“No valid AMP license was found. Please run ampinstmgr reactivate FiveM02 to reactivate this instance.”
and this with every new instant I create
I have the problem since I made an update
As first issue
17:12:22 Waiting for AMP instance to start...
AMP instance FiveM02 is now running.
17:13:00 Instance FiveM02 has stopped.
As second edition
Anonymous
Failure to make API call to FiveM02 (http://127.0.0.1:8086/API/Core/GetAPISpec) - retried 10 times : An error occurred while sending the request.
HttpRequestException
[0] (HttpRequestException) : An error occurred while sending the request.
at ADSModule.WebMethods.<MakeInstanceRequest>() at ADSModule.WebMethods.<Servers>()
WebException
[1] (WebException) : Die Verbindung mit dem Remoteserver kann nicht hergestellt werden.
at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context) at Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
SocketException
[2] (SocketException) : Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:8086
at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult) at Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
Created new instans
System Neustart und auch den key datai manuel rein kopiert in die instans
[15:42:06] [Program Info] : Starting AMP version 2.4.0.4 (Halimede), built 10/09/2022 16:30
[15:42:06] [Program Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[15:42:06] [Program Info] : Running in a HyperV environment.
[15:42:06] [Core Warning] : Current time zone is set to Mitteleuropäische Zeit - It is recommended you switch to UTC+0 to avoid time-zone related issues
[15:42:06] [Program Info] : OS: Windows / x86_64
[15:42:06] [Program Info] : CPU: AMD Ryzen 7 1800X Eight-Core Processor (6C/12T)
[15:42:06] [Program Info] : AMP Instance ID: 42505fbf-504c-4cb0-8815-24d573903cff
[15:42:06] [Core Info] : Loaded FiveMModule version 1.0.0.0 by CubeCoders Limited
[15:42:06] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[15:42:06] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[15:42:07] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[15:42:07] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[15:42:07] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[15:42:07] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[15:42:07] [Core Info] : Licence Present: AMP Professional Edition (Licenced to thomas Bohm)
[15:42:07] [FileManager Notice] : No SSH keypair available for embedded server, generating new keypair...
[15:42:07] [FileManager Notice] : Generated new keypair with fingerprint ffuIhrWF759MLuS6l0+wPN5I27Ge7JdbULtPA5dzIXc=
[15:42:07] [FileManager Notice] : Using keypair with fingerprint ffuIhrWF759MLuS6l0+wPN5I27Ge7JdbULtPA5dzIXc=
[15:42:07] [ModuleLoader Info] : SFTP Server started on 0.0.0.0:2228
[15:42:07] [Core Error] : No valid AMP licence was found. Please run `ampinstmgr reactivate FiveM01` to reactivate this instance.
:admin
17:47:01
AMP instance FiveM01 is now running.
Managed remote instance FiveM01 at http://127.0.0.1:8085/
Authentication token for admin requested by ManageInstance on behalf of admin
:Anonymous
17:47:22
Failure to make API call to FiveM01 (http://127.0.0.1:8085/API/Core/GetAPISpec) - retried 10 times : An error occurred while sending the request.
WebException
SocketException
[2] (SocketException) : Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:8085
17:48:00
Instance FiveM01 has stopped.
Hello This is the output When I enter the following command “ampinstmgr reactivate FiveM01”
C:\Users\Assindia>ampinstmgr reaktivieren FiveM01
[Info] AMP Instance Manager v2.3.4.4 gebaut 26/07/2022 20:09
[Info] Release spec: Freigabe - erstellt von CUBECODERS/buildbot auf CCL-DEV
Bitte geben Sie den Wert für den Lizenzschlüssel ein
[Info] Checking licence key...
[Info] Licence Type: AMP Professional
[Info] Current Usage: 5
[Info] Reactivating instance FiveM01...
[Error] FileNotFoundException
[Error] [0] (FileNotFoundException) : Die Datei oder Assembly "mHttp, Version=0.1.6296.32466, Culture=neutral, PublicKeyToken=null" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
[Error] ReflectionTypeLoadException
[Error] [0] (ReflectionTypeLoadException) : Mindestens ein Typ in der Assembly kann nicht geladen werden. Rufen Sie die LoaderExceptions-Eigenschaft ab, wenn Sie weitere Informationen benötigen.
[Error] bei InstanceManagerPlugin.LocalInstanceManager.GetProvisionArguments(String ModuleName)
[Info] Done.
