OS Name/Version:
Problem Description: Failed to login to remote instance. AMP tried to login to auth server at http://localhost:8080/ but it could not be reached. Please make sure that the AuthServerURL setting in AMPConfig.conf for this instance is valid and addresses your ADS controller/standalone instance. An error occurred while sending the request. - Unable to connect to the remote server
provides syntax highlighting.
- Step 1
- Step 2
- Step 3
