OS Name/Version:Ubuntu 20.04
Product Name/Version: 2.3.2.4
Need assistance setting up a server using Fabric. This is my first time ever using AMP so am new to both
Fabric is client side only not server for me server side i run paper server change that where you see official
Fabric can be setup on a server. I can do this outside of AMP setting up a server manually. enix_lin has shown most of what is required judging from several videos on the internet. However, I still get an error: “Error: Could not find or load main class net.fabricmc.loader.impl.launch.server.FabricServerLauncher
Caused by: java.lang.ClassNotFoundException: net.fabricmc.loader.impl.launch.server.FabricServerLauncher”. Any ideas how to fix that?
Solved it. The Fabric installer also creates a libraries folder. You need to zip that, copy it to the same location as the server jar file you copied then unzip it.
Also, there is already a libraries folder there, you may need to delete it. I’m not sure, but that is what I did.
