My panel has been attacked for days
OS Name/Version:
Debian 12 64bit
Amp 2.5.1.8 - 20240917.2
Hello, I have had someone attacking my panel for a week
17:19:16
SFTP connection request from xxx.xxx.xx.xxx (OpenSSH)
SFTP authentication denied for odoo@xxx.xxx.xx.xxx : Failure
17:19:36
SFTP authentication denied for hwhiaiuser@xxx.xxx.xx.xxx : Failure
17:20:20
188.190.10.144 has been banned from SFTP, ignoring connection attempt…
17:20:45
SFTP authentication denied for chia@xxx.xxx.xx.xxx : Failure
I actually banned him with iptables -A INPUT -s xxx.xxx.xx.xxx -j DROP but he continues. And why are all users locked out by the server manager? I have to disable rate-limit logins every time so that I can log in again via SFTP. Shouldn’t this only apply to the IP that is attacking and not to all users?
Known issue, there’s a slight bug in AMP’s rate limiter that was brought to light by the botnet (accidentally rate limits things due to how the internal auth server validates SFTP logins).
You have some firewall setup preventing you from blocking the IPs properly, not an AMP-related issue. I’ve been able to block things fine, but there’s some other users with a similar firewall issue. No clue what’s different tbh.
Is there a way to permanently block the IPs for AMP?
Use iptables -I rather than iptables -A
Thank you very much.
I’ve tried it now and haven’t seen any login attempts in the log for 10 minutes.
