Systen: WIndows
Product Name/Version: v2.3.2, built 31/01/2022 18:02
Wanted to ask if I could somehow add a 2 data carrier for amp because my 1 is almost full
Systen: WIndows
There isn’t much to go on in your description.
When originally testing I only used a small fixed disk on my VM, once I was happy I went and increased the VM disk size and used Partmagic to extend the OS partition size.
I cant see any settings for changing the base path for instances within AMP itself, however you can probably do it if you feel like diving deeper into the configs and options.
The other option is to spin up another VM with AMP on and have it as a child / Master configuration using that other disk.
