OS Name/Version: ubuntu server 24.04.3
Product Name/Version: AMP 2.6.3 - 20250926.1
Problem Description: I tried to add some mods but now it just crashes on startup.
15:27:55
2025-10-20 19:27:55,762 main WARN Advanced terminal features are not available in this environment
main/INFO15:27:55
ModLauncher running: args [--launchTarget, forgeserver, --fml.forgeVersion, 47.4.5, --fml.mcVersion, 1.20.1, --fml.forgeGroup, net.minecraftforge, --fml.mcpVersion, 20230612.114412]
ModLauncher 10.0.9+10.0.9+main.dcd20f30 starting: java version 21.0.8 by Eclipse Adoptium; OS Linux arch amd64 version 6.8.0-85-generic
15:27:56
ImmediateWindowProvider not loading because launch target is forgeserver
SpongePowered MIXIN Subsystem Version=0.8.5 Source=union:/home/amp/.ampdata/instances/ThugShakerCentral01/Minecraft/libraries/org/spongepowered/mixin/0.8.5/mixin-0.8.5.jar%2365!/ Service=ModLauncher Env=SERVER
main/WARN15:27:57
Mod file /home/amp/.ampdata/instances/ThugShakerCentral01/Minecraft/libraries/net/minecraftforge/fmlcore/1.20.1-47.4.5/fmlcore-1.20.1-47.4.5.jar is missing mods.toml file
Mod file /home/amp/.ampdata/instances/ThugShakerCentral01/Minecraft/libraries/net/minecraftforge/javafmllanguage/1.20.1-47.4.5/javafmllanguage-1.20.1-47.4.5.jar is missing mods.toml file
Mod file /home/amp/.ampdata/instances/ThugShakerCentral01/Minecraft/libraries/net/minecraftforge/lowcodelanguage/1.20.1-47.4.5/lowcodelanguage-1.20.1-47.4.5.jar is missing mods.toml file
Mod file /home/amp/.ampdata/instances/ThugShakerCentral01/Minecraft/libraries/net/minecraftforge/mclanguage/1.20.1-47.4.5/mclanguage-1.20.1-47.4.5.jar is missing mods.toml file
Attempted to select two dependency jars from JarJar which have the same identification: Mod File: and Mod File: . Using Mod File:
Attempted to select a dependency jar for JarJar which was passed in as source: curios. Using Mod File: /home/amp/.ampdata/instances/ThugShakerCentral01/Minecraft/mods/curios-forge-5.14.1+1.20.1.jar
Attempted to select a dependency jar for JarJar which was passed in as source: resourcefullib. Using Mod File: /home/amp/.ampdata/instances/ThugShakerCentral01/Minecraft/mods/resourcefullib-forge-1.20.1-2.1.29.jar
main/INFO15:27:57
Found 33 dependencies adding them to mods collection
Console15:27:58
Initializing Polytone Transformers
15:28:00
- mutantmonsters 8.0.7
- mutil 6.2.0
- naturalist 5.0pre3
\-- midnightlib 1.4.2
- notreepunching 7.1.0
- nyfsspiders 2.1.1
- octolib 0.5.0.1
- ohthetreesyoullgrow 1.4.2
- pehkui 3.8.2+1.20.1-forge
- phantasm 1.0.1
- playeranimator 1.0.2-rc1+1.20
- polytone 1.20-3.5.9
- projectile_damage 3.2.2+1.20.1
- puzzleslib 8.1.33
\-- puzzlesaccessapi 20.1.1
- quark 4.0-462
- radium 0.12.4+git.26c9d8e
- railways 1.6.13-alpha+forge-mc1.20.1
- ramcompat 0.1.4
- relics 0.8.0.11
- resourcefulconfig 2.1.3
- resourcefullib 2.1.29
- soulsweapons 1.2.4-1.20.1-forge}
- spartanfire 2.1.0
- spartanshields 3.1.1
- spartantoolkit 1.20.1-1.6.1
- spartantwilight 1.20.1-3.1.1
- spartanweaponry 3.2.1
- t_and_t 0.0NONE
- terrablender 3.0.1.10
- twilightforest 4.3.2508
- vminus 3.3.1
- watut 1.20.1-1.2.3
- waystones 14.1.17
- yet_another_config_lib_v3 3.6.6+1.20.1-forge
- yungsapi 1.20-Forge-4.0.6
- yungsbridges 1.20-Forge-4.0.3
- zeta 1.0-30
main/WARN15:28:00
Reference map 'itemselector.refmap.json' for l2itemselector.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map 'cristellib-forge-refmap.json' for cristellib.mixins.json could not be read. If this is a development environment you can ignore this message
main/ERROR15:28:00
Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
main/WARN15:28:00
Error loading class: net/minecraft/client/gui/screens/Screen (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER)
@Mixin target net.minecraft.client.gui.screens.Screen was not found relics.mixins.json:ScreenMixin
main/ERROR15:28:01
Attempted to load class net/minecraft/client/renderer/item/ItemProperties for invalid dist DEDICATED_SERVER
main/WARN15:28:01
Error loading class: net/minecraft/client/renderer/item/ItemProperties (java.lang.RuntimeException: Attempted to load class net/minecraft/client/renderer/item/ItemProperties for invalid dist DEDICATED_SERVER)
@Mixin target net.minecraft.client.renderer.item.ItemProperties was not found mixins.vminus.json:items.ItemPropertiesMixin
Error loading class: net/raphimc/immediatelyfast/feature/core/BatchableBufferSource (java.lang.ClassNotFoundException: net.raphimc.immediatelyfast.feature.core.BatchableBufferSource)
Error loading class: dev/tr7zw/skinlayers/render/CustomizableModelPart (java.lang.ClassNotFoundException: dev.tr7zw.skinlayers.render.CustomizableModelPart)
Error loading class: me/jellysquid/mods/sodium/client/render/vertex/buffer/SodiumBufferBuilder (java.lang.ClassNotFoundException: me.jellysquid.mods.sodium.client.render.vertex.buffer.SodiumBufferBuilder)
Error loading class: net/fabricmc/fabric/impl/datagen/FabricDataGenHelper (java.lang.ClassNotFoundException: net.fabricmc.fabric.impl.datagen.FabricDataGenHelper)
Error loading class: net/p3pp3rf1y/sophisticatedbackpacks/network/BackpackOpenMessage (java.lang.ClassNotFoundException: net.p3pp3rf1y.sophisticatedbackpacks.network.BackpackOpenMessage)
Error loading class: yalter/mousetweaks/handlers/GuiContainerHandler (java.lang.ClassNotFoundException: yalter.mousetweaks.handlers.GuiContainerHandler)
Error loading class: yalter/mousetweaks/Main (java.lang.ClassNotFoundException: yalter.mousetweaks.Main)
Force-disabling mixin 'alloc.blockstate.StateMixin' as option 'mixin.alloc.blockstate' (added by mods [ferritecore]) disables it and children
main/INFO15:28:02
[java.lang.ThreadGroup:uncaughtException:698]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:71)
[java.lang.ThreadGroup:uncaughtException:698]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.Launcher.run(Launcher.java:108)
[java.lang.ThreadGroup:uncaughtException:698]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.Launcher.main(Launcher.java:78)
[java.lang.ThreadGroup:uncaughtException:698]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:26)
[java.lang.ThreadGroup:uncaughtException:698]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:23)
[java.lang.ThreadGroup:uncaughtException:698]: at cpw.mods.bootstraplauncher@1.1.2/cpw.mods.bootstraplauncher.BootstrapLauncher.main(BootstrapLauncher.java:141)
[java.lang.Throwable:printStackTrace:660]: Caused by: java.lang.reflect.InvocationTargetException
[java.lang.Throwable:printStackTrace:660]: at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:118)
[java.lang.Throwable:printStackTrace:660]: at java.base/java.lang.reflect.Method.invoke(Method.java:580)
[java.lang.Throwable:printStackTrace:660]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.5/net.minecraftforge.fml.loading.targets.CommonLaunchHandler.runTarget(CommonLaunchHandler.java:111)
[java.lang.Throwable:printStackTrace:660]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.5/net.minecraftforge.fml.loading.targets.CommonLaunchHandler.serverService(CommonLaunchHandler.java:103)
[java.lang.Throwable:printStackTrace:660]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.5/net.minecraftforge.fml.loading.targets.CommonServerLaunchHandler.lambda$makeService$0(CommonServerLaunchHandler.java:27)
[java.lang.Throwable:printStackTrace:660]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.LaunchServiceHandlerDecorator.launch(LaunchServiceHandlerDecorator.java:30)
[java.lang.Throwable:printStackTrace:660]: ... 7 more
[java.lang.Throwable:printStackTrace:673]: Caused by: java.lang.ExceptionInInitializerError
[java.lang.Throwable:printStackTrace:673]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.network.chat.MutableComponent.m_237204_(MutableComponent.java:29)
[java.lang.Throwable:printStackTrace:673]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.network.chat.Component.m_237115_(Component.java:444)
[java.lang.Throwable:printStackTrace:673]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.commands.BrigadierExceptions.<clinit>(BrigadierExceptions.java:24)
[java.lang.Throwable:printStackTrace:673]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.SharedConstants.<clinit>(SharedConstants.java:216)
[java.lang.Throwable:printStackTrace:673]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.server.Main.main(Main.java:69)
[java.lang.Throwable:printStackTrace:673]: at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
[java.lang.Throwable:printStackTrace:673]: ... 12 more
[java.lang.Throwable:lockedPrintStackTrace:696]: Caused by: java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
[java.lang.Throwable:lockedPrintStackTrace:696]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.5/net.minecraftforge.fml.loading.RuntimeDistCleaner.processClassWithFlags(RuntimeDistCleaner.java:57)
[java.lang.Throwable:lockedPrintStackTrace:696]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.LaunchPluginHandler.offerClassNodeToPlugins(LaunchPluginHandler.java:88)
[java.lang.Throwable:lockedPrintStackTrace:696]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.ClassTransformer.transform(ClassTransformer.java:120)
[java.lang.Throwable:lockedPrintStackTrace:696]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.TransformingClassLoader.maybeTransformClassBytes(TransformingClassLoader.java:50)
[java.lang.Throwable:lockedPrintStackTrace:696]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.readerToClass(ModuleClassLoader.java:113)
[java.lang.Throwable:lockedPrintStackTrace:696]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.lambda$findClass$15(ModuleClassLoader.java:219)
[java.lang.Throwable:lockedPrintStackTrace:696]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadFromModule(ModuleClassLoader.java:229)
[java.lang.Throwable:lockedPrintStackTrace:696]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.findClass(ModuleClassLoader.java:219)
[java.lang.Throwable:lockedPrintStackTrace:696]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadClass(ModuleClassLoader.java:135)
[java.lang.Throwable:lockedPrintStackTrace:696]: at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:526)
[java.lang.Throwable:lockedPrintStackTrace:696]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.handler$bcc000$etf$illegalPathOverride(ResourceLocation.java:525)
[java.lang.Throwable:lockedPrintStackTrace:696]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.m_135841_(ResourceLocation.java:206)
[java.lang.Throwable:lockedPrintStackTrace:696]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.m_245185_(ResourceLocation.java:241)
[java.lang.Throwable:lockedPrintStackTrace:696]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.<init>(ResourceLocation.java:40)
[java.lang.Throwable:lockedPrintStackTrace:696]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.network.chat.Style.<clinit>(Style.java:39)
[java.lang.Throwable:lockedPrintStackTrace:696]: ... 18 more
Console15:28:02
Exception in thread "main"
- Step 1: removed all fabric mods and replaced fabric with forge
- Step 2: added all forge mods, deleted all client side mods
- Step 3: tried to start server but didnt work and got errors
Copied console a bunch of times and asked chatgpt what mods to delete but that never worked.
