Newer versions of AMP will automatically download the latest server templates whenever you restart the ADS instance, or if you manually request them through the menu. There are some cases where you might not have the latest templates. This is usually due to one of two reasons, the server is missing Git, or there are different files than it expects in the template directory. Try the steps below before reaching out for support.
- Ensure you have Git installed: AMP Dependencies - Git
- Reboot the OS after installing Git.
- In the web interface, navigate to
Configuration-->Instance Deployment-->Instance Management-->Configuration Repositories. Make sure you have theCubeCoders/AMPTemplates:mainrepo listed. Press theFetch Latestbutton. You can verify it downloaded under the Deployment Log tab.Updating remote source CubeCoders/AMPTemplates Cloning into 'CubeCoders-AMPTemplates-main'... - Refresh the browser and attempt to create an instance again.
- If the instance list still doesn’t populate, navigate to the File Manager and delete
ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates-main. Then try steps 3 and 4 again.
