OS Name/Version:
Linux Ubuntu Server 24.04 LTS - aarch64 version
AMP version 2.6.0.6 (Phobos)
[22:27:51] [Program Info/1] : Starting AMP version 2.6.0.6 (Phobos), built 20/11/2024 20:57
[22:27:51] [Program Info/1] : Stream: Mainline / Release (aarch64) - built by CUBECODERS/buildbot on CCL-DEV
[22:27:51] [Core Info/1] : Loading configuration from provisionargs.kvp...
[22:27:51] [Program Info/1] : Running in a QEMU KVM environment.
[22:27:51] [Program Info/1] : OS: Linux / aarch64
[22:27:51] [Program Info/1] : CPU: ARM Neoverse-N1 (2C/2T)
[22:27:51] [Program Info/1] : RAM: 11933MB
[22:27:51] [Program Info/1] : AMP Instance ID: c3b8c2d7-8e80-4c17-8e54-69107a32a0e8
[22:27:51] [Program Info/1] : Performing first-time setup for this instance, please wait...
[22:27:51] [Core Info/1] : Loaded GenericModule version 2.6.0.6 by CubeCoders Limited
[22:27:51] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[22:27:51] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[22:27:51] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[22:27:51] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[22:27:51] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[22:27:51] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[22:27:51] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[22:27:51] [System Error/11] : Missing plugin/assembly: MaxMind.Db (/home/amp/.ampdata/instances/MCBedrock01/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[22:27:51] [Loader Info/1] : GenericModule requests dependency steamcmdplugin...
[22:27:51] [System Info/11] : GeoIP database not found, downloading...
[22:27:51] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[22:27:51] [Loader Info/1] : GenericModule requests dependency RCONPlugin...
[22:27:51] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[22:27:52] [Core Warning/1] : No such setting node: GenericModule.App.TemplateMatchRegex - maybe the relevant plugin/module isn't loaded?
[22:27:52] [Core Warning/1] : No such setting node: GenericModule.Console.ActivateLogRegex - maybe the relevant plugin/module isn't loaded?
[22:27:52] [Core Info/1] : Performing activation, please wait...
[22:27:52] [Core Info/1] : Activated successfully.
[22:27:52] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[22:27:52] [Program Info/1] : AMP has completed its first time setup. Saving settings and shutting down.
Create New Instance
Choose Minecraft Server Bedrock edition
Start the server
Search in the forum for something similar
Mike
16 December 2024 16:24
2
This message can be ignored, and is unrelated to any other problems you may be having. If something isn’t working, describe what the actual presenting problem is. This log simply shows a normal instance creation and first time setup.
Here is the full log when trying to launch the server:
[22:20:56] [Program Info/1] : Starting AMP version 2.6.0.6 (Phobos), built 20/11/2024 20:57
[22:20:56] [Program Info/1] : Stream: Mainline / Release (aarch64) - built by CUBECODERS/buildbot on CCL-DEV
[22:20:56] [Program Info/1] : Running in a QEMU KVM environment.
[22:20:56] [Program Info/1] : OS: Linux / aarch64
[22:20:56] [Program Info/1] : CPU: ARM Neoverse-N1 (2C/2T)
[22:20:56] [Program Info/1] : RAM: 11933MB
[22:20:56] [Program Info/1] : AMP Instance ID: 1ff10cb6-15b8-4a62-b416-9c96b335b5b6
[22:20:56] [Core Info/1] : Loaded MinecraftModule version 2.6.0.6 by CubeCoders Limited
[22:20:56] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[22:20:56] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[22:20:56] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[22:20:56] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[22:20:56] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[22:20:56] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[22:20:56] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[22:20:56] [System Error/9] : Missing plugin/assembly: MaxMind.Db (/home/amp/.ampdata/instances/MCJava01/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[22:20:56] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[22:20:57] [System Info/10] : Updating Modpack cache for 94 modpacks...
[22:20:57] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair...
[22:20:57] [FileManager Notice/1] : Generated new keypair with fingerprint hQGimRCLAZT6Ch26MQFaBEmJyUUUMY98q5ndaLSuXMc=
[22:20:57] [Loader Notice/1] : Using keypair with fingerprint hQGimRCLAZT6Ch26MQFaBEmJyUUUMY98q5ndaLSuXMc=
[22:20:57] [Loader Info/1] : SFTP Server started on 0.0.0.0:2224
[22:20:57] [System Warning/9] : Unable to get Bedrock version data from https://www.minecraft.net/en-us/download/server/bedrock: Match not found.
[22:20:57] [System Info/9] : Trying first Bedrock info fallback...
[22:20:58] [Core Info/1] : Webserver started on http://127.0.0.1:8081
[22:20:58] [System Info/7] : Checking for AMP updates...
[22:20:58] [System Info/10] : Startup mode is UpdateAndStart.
[22:20:58] [System Info/10] : AMP is up to date.
[22:20:58] [System Info/10] : Update complete.
[22:21:02] [System Warning/10] : Unable to get first fallback Bedrock version data from https://www.minecraft.net/en-us/download/server/bedrock: Match not found.
[22:21:02] [System Info/10] : Trying second Bedrock info fallback...
[22:21:02] [System Info/10] : Latest Bedrock version: 1.21.31.04
[22:26:35] [System Activity/27] : Authentication attempt for user zmc.blox.balls from 127.0.0.1
[22:26:35] [System Activity/26] : Authentication success
[22:26:39] [Core:zmc.blox.balls Activity/27] : Starting the application.
[22:26:39] [Minecraft:zmc.blox.balls Info/27] : Java located at /usr/lib/jvm/temurin-21-jdk-arm64/bin/java
[22:26:39] [Minecraft:zmc.blox.balls Info/27] : Using 'Official' compatibility mode.
Unpacking 1.21.4/server-1.21.4.jar (versions:1.21.4) to versions/1.21.4/server-1.21.4.jar
Unpacking com/fasterxml/jackson/core/jackson-annotations/2.13.4/jackson-annotations-2.13.4.jar (libraries:com.fasterxml.jackson.core:jackson-annotations:2.13.4) to libraries/com/fasterxml/jackson/core/jackson-annotations/2.13.4/jackson-annotations-2.13.4.jar
Unpacking com/fasterxml/jackson/core/jackson-core/2.13.4/jackson-core-2.13.4.jar (libraries:com.fasterxml.jackson.core:jackson-core:2.13.4) to libraries/com/fasterxml/jackson/core/jackson-core/2.13.4/jackson-core-2.13.4.jar
Unpacking com/fasterxml/jackson/core/jackson-databind/2.13.4.2/jackson-databind-2.13.4.2.jar (libraries:com.fasterxml.jackson.core:jackson-databind:2.13.4.2) to libraries/com/fasterxml/jackson/core/jackson-databind/2.13.4.2/jackson-databind-2.13.4.2.jar
Unpacking com/github/oshi/oshi-core/6.6.5/oshi-core-6.6.5.jar (libraries:com.github.oshi:oshi-core:6.6.5) to libraries/com/github/oshi/oshi-core/6.6.5/oshi-core-6.6.5.jar
Unpacking com/github/stephenc/jcip/jcip-annotations/1.0-1/jcip-annotations-1.0-1.jar (libraries:com.github.stephenc.jcip:jcip-annotations:1.0-1) to libraries/com/github/stephenc/jcip/jcip-annotations/1.0-1/jcip-annotations-1.0-1.jar
Unpacking com/google/code/gson/gson/2.11.0/gson-2.11.0.jar (libraries:com.google.code.gson:gson:2.11.0) to libraries/com/google/code/gson/gson/2.11.0/gson-2.11.0.jar
Unpacking com/google/guava/failureaccess/1.0.2/failureaccess-1.0.2.jar (libraries:com.google.guava:failureaccess:1.0.2) to libraries/com/google/guava/failureaccess/1.0.2/failureaccess-1.0.2.jar
Unpacking com/google/guava/guava/33.3.1-jre/guava-33.3.1-jre.jar (libraries:com.google.guava:guava:33.3.1-jre) to libraries/com/google/guava/guava/33.3.1-jre/guava-33.3.1-jre.jar
Unpacking com/microsoft/azure/msal4j/1.17.2/msal4j-1.17.2.jar (libraries:com.microsoft.azure:msal4j:1.17.2) to libraries/com/microsoft/azure/msal4j/1.17.2/msal4j-1.17.2.jar
Unpacking com/mojang/authlib/6.0.57/authlib-6.0.57.jar (libraries:com.mojang:authlib:6.0.57) to libraries/com/mojang/authlib/6.0.57/authlib-6.0.57.jar
Unpacking com/mojang/brigadier/1.3.10/brigadier-1.3.10.jar (libraries:com.mojang:brigadier:1.3.10) to libraries/com/mojang/brigadier/1.3.10/brigadier-1.3.10.jar
Unpacking com/mojang/datafixerupper/8.0.16/datafixerupper-8.0.16.jar (libraries:com.mojang:datafixerupper:8.0.16) to libraries/com/mojang/datafixerupper/8.0.16/datafixerupper-8.0.16.jar
Unpacking com/mojang/jtracy/1.0.29/jtracy-1.0.29.jar (libraries:com.mojang:jtracy:1.0.29) to libraries/com/mojang/jtracy/1.0.29/jtracy-1.0.29.jar
Unpacking com/mojang/logging/1.5.10/logging-1.5.10.jar (libraries:com.mojang:logging:1.5.10) to libraries/com/mojang/logging/1.5.10/logging-1.5.10.jar
Unpacking com/nimbusds/content-type/2.3/content-type-2.3.jar (libraries:com.nimbusds:content-type:2.3) to libraries/com/nimbusds/content-type/2.3/content-type-2.3.jar
Unpacking com/nimbusds/lang-tag/1.7/lang-tag-1.7.jar (libraries:com.nimbusds:lang-tag:1.7) to libraries/com/nimbusds/lang-tag/1.7/lang-tag-1.7.jar
Unpacking com/nimbusds/nimbus-jose-jwt/9.40/nimbus-jose-jwt-9.40.jar (libraries:com.nimbusds:nimbus-jose-jwt:9.40) to libraries/com/nimbusds/nimbus-jose-jwt/9.40/nimbus-jose-jwt-9.40.jar
Unpacking com/nimbusds/oauth2-oidc-sdk/11.18/oauth2-oidc-sdk-11.18.jar (libraries:com.nimbusds:oauth2-oidc-sdk:11.18) to libraries/com/nimbusds/oauth2-oidc-sdk/11.18/oauth2-oidc-sdk-11.18.jar
Unpacking commons-io/commons-io/2.17.0/commons-io-2.17.0.jar (libraries:commons-io:commons-io:2.17.0) to libraries/commons-io/commons-io/2.17.0/commons-io-2.17.0.jar
Unpacking io/netty/netty-buffer/4.1.115.Final/netty-buffer-4.1.115.Final.jar (libraries:io.netty:netty-buffer:4.1.115.Final) to libraries/io/netty/netty-buffer/4.1.115.Final/netty-buffer-4.1.115.Final.jar
Unpacking io/netty/netty-codec/4.1.115.Final/netty-codec-4.1.115.Final.jar (libraries:io.netty:netty-codec:4.1.115.Final) to libraries/io/netty/netty-codec/4.1.115.Final/netty-codec-4.1.115.Final.jar
Unpacking io/netty/netty-common/4.1.115.Final/netty-common-4.1.115.Final.jar (libraries:io.netty:netty-common:4.1.115.Final) to libraries/io/netty/netty-common/4.1.115.Final/netty-common-4.1.115.Final.jar
Unpacking io/netty/netty-handler/4.1.115.Final/netty-handler-4.1.115.Final.jar (libraries:io.netty:netty-handler:4.1.115.Final) to libraries/io/netty/netty-handler/4.1.115.Final/netty-handler-4.1.115.Final.jar
Unpacking io/netty/netty-resolver/4.1.115.Final/netty-resolver-4.1.115.Final.jar (libraries:io.netty:netty-resolver:4.1.115.Final) to libraries/io/netty/netty-resolver/4.1.115.Final/netty-resolver-4.1.115.Final.jar
Unpacking io/netty/netty-transport/4.1.115.Final/netty-transport-4.1.115.Final.jar (libraries:io.netty:netty-transport:4.1.115.Final) to libraries/io/netty/netty-transport/4.1.115.Final/netty-transport-4.1.115.Final.jar
Unpacking io/netty/netty-transport-classes-epoll/4.1.115.Final/netty-transport-classes-epoll-4.1.115.Final.jar (libraries:io.netty:netty-transport-classes-epoll:4.1.115.Final) to libraries/io/netty/netty-transport-classes-epoll/4.1.115.Final/netty-transport-classes-epoll-4.1.115.Final.jar
Unpacking io/netty/netty-transport-native-epoll/4.1.115.Final/netty-transport-native-epoll-4.1.115.Final-linux-x86_64.jar (libraries:io.netty:netty-transport-native-epoll:4.1.115.Final:linux-x86_64) to libraries/io/netty/netty-transport-native-epoll/4.1.115.Final/netty-transport-native-epoll-4.1.115.Final-linux-x86_64.jar
Unpacking io/netty/netty-transport-native-epoll/4.1.115.Final/netty-transport-native-epoll-4.1.115.Final-linux-aarch_64.jar (libraries:io.netty:netty-transport-native-epoll:4.1.115.Final:linux-aarch_64) to libraries/io/netty/netty-transport-native-epoll/4.1.115.Final/netty-transport-native-epoll-4.1.115.Final-linux-aarch_64.jar
Unpacking io/netty/netty-transport-native-unix-common/4.1.115.Final/netty-transport-native-unix-common-4.1.115.Final.jar (libraries:io.netty:netty-transport-native-unix-common:4.1.115.Final) to libraries/io/netty/netty-transport-native-unix-common/4.1.115.Final/netty-transport-native-unix-common-4.1.115.Final.jar
Unpacking it/unimi/dsi/fastutil/8.5.15/fastutil-8.5.15.jar (libraries:it.unimi.dsi:fastutil:8.5.15) to libraries/it/unimi/dsi/fastutil/8.5.15/fastutil-8.5.15.jar
Unpacking net/java/dev/jna/jna/5.15.0/jna-5.15.0.jar (libraries:net.java.dev.jna:jna:5.15.0) to libraries/net/java/dev/jna/jna/5.15.0/jna-5.15.0.jar
Unpacking net/java/dev/jna/jna-platform/5.15.0/jna-platform-5.15.0.jar (libraries:net.java.dev.jna:jna-platform:5.15.0) to libraries/net/java/dev/jna/jna-platform/5.15.0/jna-platform-5.15.0.jar
Unpacking net/minidev/accessors-smart/2.5.1/accessors-smart-2.5.1.jar (libraries:net.minidev:accessors-smart:2.5.1) to libraries/net/minidev/accessors-smart/2.5.1/accessors-smart-2.5.1.jar
Unpacking net/minidev/json-smart/2.5.1/json-smart-2.5.1.jar (libraries:net.minidev:json-smart:2.5.1) to libraries/net/minidev/json-smart/2.5.1/json-smart-2.5.1.jar
Unpacking net/sf/jopt-simple/jopt-simple/5.0.4/jopt-simple-5.0.4.jar (libraries:net.sf.jopt-simple:jopt-simple:5.0.4) to libraries/net/sf/jopt-simple/jopt-simple/5.0.4/jopt-simple-5.0.4.jar
Unpacking org/apache/commons/commons-lang3/3.17.0/commons-lang3-3.17.0.jar (libraries:org.apache.commons:commons-lang3:3.17.0) to libraries/org/apache/commons/commons-lang3/3.17.0/commons-lang3-3.17.0.jar
Unpacking org/apache/logging/log4j/log4j-api/2.24.1/log4j-api-2.24.1.jar (libraries:org.apache.logging.log4j:log4j-api:2.24.1) to libraries/org/apache/logging/log4j/log4j-api/2.24.1/log4j-api-2.24.1.jar
Unpacking org/apache/logging/log4j/log4j-core/2.24.1/log4j-core-2.24.1.jar (libraries:org.apache.logging.log4j:log4j-core:2.24.1) to libraries/org/apache/logging/log4j/log4j-core/2.24.1/log4j-core-2.24.1.jar
Unpacking org/apache/logging/log4j/log4j-slf4j2-impl/2.24.1/log4j-slf4j2-impl-2.24.1.jar (libraries:org.apache.logging.log4j:log4j-slf4j2-impl:2.24.1) to libraries/org/apache/logging/log4j/log4j-slf4j2-impl/2.24.1/log4j-slf4j2-impl-2.24.1.jar
Unpacking org/joml/joml/1.10.8/joml-1.10.8.jar (libraries:org.joml:joml:1.10.8) to libraries/org/joml/joml/1.10.8/joml-1.10.8.jar
Unpacking org/lz4/lz4-java/1.8.0/lz4-java-1.8.0.jar (libraries:org.lz4:lz4-java:1.8.0) to libraries/org/lz4/lz4-java/1.8.0/lz4-java-1.8.0.jar
Unpacking org/ow2/asm/asm/9.6/asm-9.6.jar (libraries:org.ow2.asm:asm:9.6) to libraries/org/ow2/asm/asm/9.6/asm-9.6.jar
Unpacking org/slf4j/slf4j-api/2.0.16/slf4j-api-2.0.16.jar (libraries:org.slf4j:slf4j-api:2.0.16) to libraries/org/slf4j/slf4j-api/2.0.16/slf4j-api-2.0.16.jar
Starting net.minecraft.server.Main
[22:26:47] [ServerMain/INFO]: Environment: Environment[sessionHost=https://sessionserver.mojang.com, servicesHost=https://api.minecraftservices.com, name=PROD]
[22:26:48] [ServerMain/INFO]: No existing world data, creating new world
[22:26:48] [ServerMain/WARN]: Failed to parse level-type default, defaulting to minecraft:normal
[22:26:50] [ServerMain/INFO]: Loaded 1370 recipes
[22:26:50] [ServerMain/INFO]: Loaded 1481 advancements
[22:26:50] [Server thread/INFO]: Starting minecraft server version 1.21.4
[22:26:50] [Server thread/INFO]: Loading properties
[22:26:50] [Server thread/INFO]: Default game type: SURVIVAL
[22:26:50] [Server thread/INFO]: Generating keypair
[22:26:50] [Server thread/INFO]: Starting Minecraft server on 0.0.0.0:25565
[22:26:50] [Server thread/INFO]: Using epoll channel type
[22:26:50] [Server thread/INFO]: Preparing level "world"
[22:27:01] [Server thread/INFO]: Preparing start region for dimension minecraft:overworld
[22:27:02] [Worker-Main-2/INFO]: Preparing spawn area: 2%
[22:27:09] [Worker-Main-2/INFO]: Preparing spawn area: 8%
[22:27:09] [Server thread/INFO]: Time elapsed: 7919 ms
[22:27:09] [Server thread/INFO]: Done (19.281s)! For help, type "help"
[22:27:59] [Server thread/INFO]: Unknown or incomplete command, see below for error
[22:27:59] [Server thread/INFO]: tps<--[HERE]
[22:28:09] [Server thread/INFO]: Server empty for 60 seconds, pausing
[22:31:59] [Minecraft Info/23] : Application stop requested
[22:31:59] [Server thread/INFO]: Stopping the server
[22:31:59] [Server thread/INFO]: Stopping server
[22:31:59] [Server thread/INFO]: Saving players
[22:31:59] [Server thread/INFO]: Saving worlds
[22:32:00] [Server thread/INFO]: Saving chunks for level 'ServerLevel[world]'/minecraft:overworld
[22:32:02] [Server thread/INFO]: Saving chunks for level 'ServerLevel[world]'/minecraft:the_end
[22:32:02] [Server thread/INFO]: Saving chunks for level 'ServerLevel[world]'/minecraft:the_nether
[22:32:02] [Server thread/INFO]: ThreadedAnvilChunkStorage (world): All chunks are saved
[22:32:02] [Server thread/INFO]: ThreadedAnvilChunkStorage (DIM1): All chunks are saved
[22:32:02] [Server thread/INFO]: ThreadedAnvilChunkStorage (DIM-1): All chunks are saved
[22:32:02] [Server thread/INFO]: ThreadedAnvilChunkStorage: All dimensions are saved
Thank you
Mike
16 December 2024 16:51
4
This is currently configured to start a Java server, not a Bedrock one.
I’m sorry!
Maybe this one is the correct one!
[16:39:45] [Program Info/1] : Starting AMP version 2.6.0.6 (Phobos), built 20/11/2024 20:57
[16:39:45] [Program Info/1] : Stream: Mainline / Release (aarch64) - built by CUBECODERS/buildbot on CCL-DEV
[16:39:45] [Program Info/1] : Running in a QEMU KVM environment.
[16:39:45] [Program Info/1] : OS: Linux / aarch64
[16:39:45] [Program Info/1] : CPU: ARM Neoverse-N1 (2C/2T)
[16:39:45] [Program Info/1] : RAM: 11933MB
[16:39:45] [Program Info/1] : AMP Instance ID: bd276e12-4d35-4e43-9765-b24d6ac336b8
[16:39:46] [Core Info/1] : Loaded GenericModule version 2.6.0.6 by CubeCoders Limited
[16:39:46] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[16:39:46] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[16:39:46] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[16:39:46] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[16:39:46] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[16:39:46] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[16:39:46] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[16:39:46] [System Error/9] : Missing plugin/assembly: MaxMind.Db (/home/amp/.ampdata/instances/MCBedrock01/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[16:39:46] [Loader Info/1] : GenericModule requests dependency steamcmdplugin...
[16:39:46] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[16:39:46] [Loader Info/1] : GenericModule requests dependency RCONPlugin...
[16:39:46] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[16:39:46] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[16:39:46] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair...
[16:39:46] [FileManager Notice/1] : Generated new keypair with fingerprint r9FnVFGALAorFVpuQJY2i6yM7zj/3Q1ZJi34H9tpKmo=
[16:39:46] [Loader Notice/1] : Using keypair with fingerprint r9FnVFGALAorFVpuQJY2i6yM7zj/3Q1ZJi34H9tpKmo=
[16:39:46] [Loader Info/1] : SFTP Server started on 0.0.0.0:2225
[16:39:47] [Core Info/1] : Webserver started on http://127.0.0.1:8082
[16:39:47] [System Info/9] : Checking for AMP updates...
[16:39:47] [System Info/10] : Startup mode is UpdateAndStart.
[16:39:47] [System Info/10] : AMP is up to date.
[16:39:56] [Generic Info/9] : Writing config file ./Minecraft/server.properties using Unicode (UTF-8) encoding.
[16:39:57] [Generic Info/9] : Writing config file ./Minecraft/server.properties using Unicode (UTF-8) encoding.
[16:39:57] [Generic Error/9] : PlatformException
[16:39:57] [Generic Error/9] : [0] (PlatformException) : An error occurred trying to start process '/home/amp/.ampdata/instances/MCBedrock01/Minecraft/bedrock_server' with working directory '/home/amp/.ampdata/instances/MCBedrock01/Minecraft/'. Exec format error
[16:39:57] [Generic Error/9] : at Diagnostics.Process.ForkAndExecProcess(ProcessStartInfo startInfo, String resolvedFilename, String[] argv, String[] envp, String cwd, Boolean setCredentials, UInt32 userId, UInt32 groupId, UInt32[] groups, Int32& stdinFd, Int32& stdoutFd, Int32& stderrFd, Boolean usesTerminal, Boolean throwOnNoExec)
at Diagnostics.Process.StartCore(ProcessStartInfo startInfo)
at ModuleShared.AMPProcess.Start()
at GenericModule.GenericApp.DoAppStartup(Boolean IsUpdating)
at GenericModule.GenericApp.Start()
Mike
16 December 2024 17:38
6
It looks like you didn’t select the option during installation to install the emulation layer which is required to run non-ARM apps on an ARM system. Open up a root shell again and run:
getamp installDarkMagicNew
Then reboot the system and try again.
Thank you for your feedback.
I’ve installed all the options in the installation! (including “CPx2 emulation”)
Here is the command output from the instructions above:
Please wait while GetAMP examines your system and network configuration...
- Checking installed packages...
- Checking environment...
- Checking network configuration...
- Detecting network type...
Platform information
You are installing AMP on an aarch64 system.
This means that many game servers will not run on this system, or may only run via CPx2 emulation which
may significantly reduce performance.
For more information on aarch64 compatible titles, please see:
https://discourse.cubecoders.com/docs?topic=1870&utm_term=aarch64
Press any key to continue.
GetAMP has detected that you are using Oracle Cloud.
Extra steps are required to run AMP on Oracle Cloud, if you have not yet done this, press CTRL+C now
to stop the setup and consult the documentation at
https://support.cubecoders.com/doc
s?topic=2307&utm_term=oracle before continuing.
Make sure you are using Ubuntu 22.04 or newer as per the guide. Older versions are not
supported on ARM hardware.
Press any key to continue if you have already done this.No such function or flag: installDarkMagicNew
Can you help? @Mike
