Minimum Spec for using AMP controller
Hey All,
I just wanted to check what the minimum specs where that could run an amp controller instance.
I want to use my oracle cloud account to host the controller while I use my actual systems to host the targets and game server instances, but I only have my E2.1 VMs available. (I’m using the other for website hosting and SQL database management).
These E2.1 VMs get 1 core and 1gb of ram with 480mbps of bandwidth. I figured since it’s just a controller and not being used for instances it would be okay, but I wanted to make sure before I go and try something that will inevitably fail.
All help is appreciated
Thanks,
You could run it on a toaster. You could run it on less than that for sure :slight_smile:
Oh perfect, so I won’t have any issues in terms of connection or performance running the controller off one of these types of instances as long as I open ports and follow the Oracle cloud guide?
