OS Name/Version:
Debian 13 (trixie)
| OS | Linux |
| Platform | Debian GNU/Linux 12 |
| System Type | x86_64 |
| Hardware Platform | Shenzhen Meigao Electronic Equipment Co.,Ltd AHBNB |
| CPU Model | 12th Gen Intel(R) Core™ i9-12900HK |
| CPU Layout | 1S/10C/20T |
| Installed RAM | 39854 |
| Virtualization | Docker |
| Network Mode | Host Mode |
| Module | MinecraftModule |
| Module Application | Minecraft |
| Loaded Plugins | FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, WebhookPlugin, LocalFileBackupPlugin, CommonCorePlugin, AnalyticsPlugin |
| Application Name | AMP |
| Application Version | 2.6.4.0 |
| Codename | Phobos |
| Tools Version | 2.6.2.2 |
| Release Stream | Mainline |
| Build Spec | Release |
| Build Date | 14/11/2025 00:12 |
| InstanceID | ac4caa22-6972-4914-9521-8ab620889ebc |
| Last Executable | |
| Last Arguments | |
| Last Process ID | 222 |
The Minecraft server will not wake when a user tries to connect
- Set Minecraft (Paper MC 1.21.9) to Sleep Mode Enable
- Set Wake from Sleep to either “When a user joins the server” or “When the server is pinged”
- Try to connect after the server sleeps
I’ve searched in these forums and I see that other people have reported similar problems but have either less “pure” connections such as connecting via playit.gg or the threads were closed a while back after 30 days inactivity. I’ve tried what I’ve found (albeit not much).
The other wrinkle is that a week ago this exact hardware was running AMP on Windows 11. In that configuration the wake worked perfectly. However, after MULTIPLE failures of Windows to apply Win 11 25H2 I gave up and reformatted the machine to Debian. I realize that I could use that to doubt the hardware except that same issue has happened on multiple PCs for me so I’m more likely to blame Microsoft.
