Minecraft - When I try to join to wakeup with floodgate
Current State Sleeping
Wake Up to join
Im using a playitgg domain to connect and when I try to wake up the server by joining it says disconnected, it works perfectly fine with geyser mc when it isnt using floodgate, but when i use floodgate it just says disconnected when i try to wake it up. Im able to wake it up using an ipv4 connections.
  • Install geyser mc on a paper server
  • Install floodgate on a paper server
  • change the auth type in the geyser config file to floodgate
  • setup a tunnle to the server using playit gg
  • boot the server and put it in sleep mode
  • try to join the server using the playit gg domain
Sleep mode isn’t really meant to work with floodgate, since sleep mode only listens on port 25565.
Sleep mode is something that AMP runs (which just shuts down the server and listens for connections), it’s not part of the vanilla game
