Minecraft - too many open files on docker instance
Product AMP ‘Decadeus’ v2.4.5.2 (Mainline)
Start Another Quality Modpack 2 on Docker Instance
When I try to launch Another Quality Modpack 2, I would get a “Too many open files” error on the console.
I believe it is linked to “ulimit” which is locked to 1024 on the docker instance.
By getting into the docker via /bin/bash, it is possible to check ulimit trying any “ulimit -n x” (x = number) to try to change the value ends in a “operation non permitted” error.
Additional infos :
default login in the docker is root.
Minecraft server works fine when docker mode is disabled
  • Get Another Quality Modpack 2
  • startserver.sh on ssh
  • link the right .jar through the interface (startserver-x.xx.jar)
  • Run the server
  • Gets a “too many open files” error
Why is the modpack trying to have 1024 files open for a single server? That sounds more like a bug that should be taken up with the modpack developer if it’s trying to open that many files at once.
This is also something that I would like to know.
I’m not a modpack specialist at all.
I tried another modpack (All of fabric 6) and had a similar result.
Maybe it’s a fabric shenanigans, I could not say.
One last thing I could try is to reduce file limit on my server to see if the instance also fails to run the minecraft sesrver.
