Minecraft - Start my Minecraft Server using ATM9 (0.2.60) modpack
Product AMP ‘Callisto’ v2.5.0.14 (Mainline)
Start my Minecraft Server using ATM9 (0.2.60) modpack. Im unsure if my version is wrong or what to do. I have never used a server side AMP panel before but decided to go with hostinger in order to both save money and take advantage of what others told me was a simple-to-use server hosting platform. Ive spent hours troubleshooting the server but nothing works. Can someone please either manually fix the server to run the modpack or walk me through the errors?
Console12:13:52
2024-06-22 16:13:52,371 main WARN Advanced terminal features are not available in this environment
main/INFO12:13:52
ModLauncher running: args [--launchTarget, forgeserver, --fml.forgeVersion, 47.2.20, --fml.mcVersion, 1.20.1, --fml.forgeGroup, net.minecraftforge, --fml.mcpVersion, 20230612.114412]
ModLauncher 10.0.9+10.0.9+main.dcd20f30 starting: java version 21.0.2 by Eclipse Adoptium; OS Linux arch amd64 version 5.10.0-30-cloud-amd64
main/WARN12:13:52
Configuration file /AMP/Minecraft/config/fml.toml is not correct. Correcting
main/INFO12:13:52
Incorrect key [earlyWindowShowCPU]: was corrected from false to null
ImmediateWindowProvider not loading because launch target is forgeserver
SpongePowered MIXIN Subsystem Version=0.8.5 Source=union:/AMP/Minecraft/libraries/org/spongepowered/mixin/0.8.5/mixin-0.8.5.jar%2365!/ Service=ModLauncher Env=SERVER
main/WARN12:13:53
Mod file /AMP/Minecraft/libraries/net/minecraftforge/fmlcore/1.20.1-47.2.20/fmlcore-1.20.1-47.2.20.jar is missing mods.toml file
Mod file /AMP/Minecraft/libraries/net/minecraftforge/javafmllanguage/1.20.1-47.2.20/javafmllanguage-1.20.1-47.2.20.jar is missing mods.toml file
Mod file /AMP/Minecraft/libraries/net/minecraftforge/lowcodelanguage/1.20.1-47.2.20/lowcodelanguage-1.20.1-47.2.20.jar is missing mods.toml file
Mod file /AMP/Minecraft/libraries/net/minecraftforge/mclanguage/1.20.1-47.2.20/mclanguage-1.20.1-47.2.20.jar is missing mods.toml file
main/INFO12:13:53
No dependencies to load found. Skipping!
12:13:55
Launching target 'forgeserver' with arguments []
modloading-worker-0/INFO12:14:04
Forge mod loading, version 47.2.20, for MC 1.20.1 with MCP 20230612.114412
MinecraftForge v47.2.20 Initialized
Forge Version Check/INFO12:14:05
Starting version check at https://files.minecraftforge.net/net/minecraftforge/forge/promotions_slim.json
Found status: OUTDATED Current: 47.2.20 Target: 47.3.0
main/INFO12:14:07
Environment: authHost='https://authserver.mojang.com', accountsHost='https://api.mojang.com', sessionHost='https://sessionserver.mojang.com', servicesHost='https://api.minecraftservices.com', name='PROD'
main/ERROR12:14:07
Invalid world directory specified, must not be null, empty or the same directory as your universe!
  • Launched and added the server pack for ATM9-0.2.60
  • Installed forge and changed it to the proper version
  • Used both the modpack itself and the server files modpack in hopes to launch and connect
This is not Hostinger support, this is the forum for AMP.
Be sure that you use the ATM9 server pack, and that you have the right modloader/version selected
