Field
Value
Operating System
Linux - Debian GNU/Linux 13 on x86_64
Product
AMP ‘Deimos’ v2.7.2.0 (Mainline)
Virtualization
Docker
Application
Minecraft
Module
MinecraftModule
Running in Container
Yes
Current State
Stopped
upload minecraft server from filezilla
when uploading i can upload files fine and i can manually make a folder in filezilla but when i try to upload a folder i get error code 106 was not a issue until latest update issue also appears to be on other already existing servers that had no issues before. i have tried running the fix perms that did nothing. also i have used two pcs same issue
Hostkey is trusted
Status: Starting upload of M:\ServerFiles-6.6\logs\almostunified\almostunified.log
Error: The channel has failed with error code 106
Error: File transfer failed
make a minecraft server
connect to sftp
attempt to upload
Mike
April 20, 2026, 9:11am
2
What does AMPs log say? Specifically at the time the upload fails.
[17:04:50] [System Activity/80] : Authentication attempt for user necro367 from 192.168.2.3
[17:04:51] [System Activity/80] : Authentication success
[17:04:51] [System Activity/80] : SFTP connection request from 192.168.2.3 (fzssh_1.2.0_FileZilla_3.70.4)
[17:04:51] [FileManager Activity/80] : SFTP login success for necro367@192.168.2.3
[17:04:51] [Rebex Error/77] : SFTP Server error occurred for necro367
[17:04:51] [Rebex Error/77] : 45a32910-f564-41ea-a259-8960bb066952 via 192.168.2.3
[17:04:51] [FileManager Error/77] : ArgumentException
[17:04:51] [FileManager Error/77] : [0] (ArgumentException) : newDirectoryPath
[17:04:51] [FileManager Error/77] : at zqivf.bwdsx.avmvx(pxqsn p0, iksfd p1)
at zqivf.hhpbr.iptxj(String p0)
at zqivf.ojevq.iptxj(String p0)
at zqivf.vqogr.iptxj(String p0)
at zqivf.hpqma.lpanu(String p0)
at zqivf.ydvmj.ypzkr(gctdl p0, Int32 p1, stwea p2)
at zqivf.ydvmj.cstap(gctdl p0)
at zqivf.ydvmj.ehkhd(CancellationToken p0)
Mike
April 20, 2026, 6:58pm
4
Try uploading as a zip instead and then extracting it in AMP.
when tryinging it seems to give up 1,146,000KB out of 1,313,000KB but looking at the logs no error?
[19:15:42] [FileManager Activity/35] : SFTP login success for necro367@192.168.2.3
[19:15:42] [FileManager Activity/76] : Trashed file ServerFiles-6.6.zip
[19:15:46] [System Activity/35] : Uploaded file ServerFiles-6.6.zip (Computer)
[19:19:51] [System Activity/78] : Authentication attempt for user necro367 from 192.168.2.3
[19:19:51] [System Activity/78] : Authentication success
[19:19:51] [System Activity/78] : SFTP connection request from 192.168.2.3 (fzssh_1.2.0_FileZilla_3.70.4)
[19:19:51] [FileManager Activity/78] : SFTP login success for necro367@192.168.2.3
i was able to upload zip from website and unzip and it worked fine wonder whats up with sftp
