Minecraft SFTP "Host Does Not Exist"
OS Name/Version: Debian 12
Product Name/Version: AMP 2.4.6.6 - 20231005.1
Problem Description: When trying to connect to the SFTP to transfer a mod pack server file, I click the link to send me to WinSCP, but it only says that the “Host Does Not Exist”. All steps done were on the PC I login to the AMP web panel from.
Step 1 Login to AMP Web Panel
Step 2 Enter Minecraft Instance
Step 3 Go to File Manager
Step 4 Click Connect to SFTP
Step 5 Hit the link to Go to WinSCP
Step 6 Error pops up saying Host Does Not Exist
I have went through the Help tab that has some common troubleshooting such as firewalls. IPV6 to IPV4. Additionally, I have also just tried manually putting in the credentials that “Connect to SFTP” gives into WinSCP, but the same error occurs.
Have you tried with sftp:// in front of the host and added the correct port in the port field?
Does the hostname in the URL match what you would expect for your server? Is it a domain or an IP?
