OS Name/Version: Lubuntu 22.04
Product Name/Version: Minecraft 1.7.10 / forge-1.7.10-10.13.4.1566-1.7.10-universal / AMP 2.4.6.6 - 20231005.1
I’ve tried setting up a Agrarian Skies 2 server using AMP but it doesn’t work. I’ve set up several FTB servers without issue (mainly because it downloads and configures it for you), but seem to have issues with AS2.
I get a message box saying that the server stopped within 5 seconds of starting and to check the log. I’ve provided the logs here
fml-server-latest.log
fml-junk-earlystartup.log
Those are the only two logs I have.
My installation is as follows;
I created a new instance, downloaded Forge version 10.13.4.1566-1.7.10. Accepted the EULA. Uploaded the server files for the AS2-server zip and placed them correctly. Set the server to have 4GB RAM. Manually chose the forge universal .jar. Chose the world-map. Set the java version to 8 (tried both TEMURIN 8 and JAVA 8 openjdk). Then I hit Start and within 5 seconds I’m hit with the “The Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.” then it changes to “Application state: Unable to run”.
Anyone who’s able to figure out what’s gone wrong here? Any help would be greatly appreciated.
Rebooting machine. Re-installing AMP. Remaking the instance. Tried all available java versions. Made sure everything is installed in the right places. Lots of google, but unable to find anything regarding AS2 on AMP.
