Minecraft - roughly every 5 minutes users and website disconnects
disconnected from game and AMP
Roughly every 5 minutes users are disconnected and this website tells me that I am disconnected and reconnecting to AMP and that as long as I have remember password on I should be able to connect still. I do not see anything wrong in the console or logs. there are no failures reported anywhere. With the instance stopped I still get disconnected from AMP roughly every 5 minutes. When the server is on, users who are disconnected get a Packet handling error report. Thanks for your help!
  • Restarted instance including just restart and a full shut down and restart
  • Decreased render distance and chunks loaded around players
  • added plugin to allow chunks to load ahead of time to decrease strain on server
Sounds like whatever system you’re running AMP on is probably being overloaded either in terms of RAM or CPU usage, either that, or there’s a networking issue with the machine you’ve installed AMP on
