| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Ready |
Chunk pregeneration restarts the server.
The chunky mod pregeneration process causes a server restart mid generation. No crash log is generated. This is independent of generation pattern, but not generation size. It worked for a radius of 1000 blocks, but not 2000 blocks. The chunk pregenerator mod does the same thing, but the server immediately crashes instead of crashing after partially completing the task.
- Run /pregen gen start ChunkGeneration SQUARE 0 0 100 or /chunky radius 2000
- If you ran the chunky command, run /chunky start
- Wait for the server to restart mid-generation.
