Minecraft - Passengers take on vehicle rotation
Virtualization HyperV
Current State Sleeping
AMP-specific bug
Expected behavior:
The pig will travel in the direction you are looking.
Actual behavior: pig starts spinning in circles. Using /tick rate 1 will resolve this issue temporarily, so will using /tick freeze and repeated /tick step 1 commands.
    1. Start 1.21.4 server (fabric/vanilla/paper)
    1. /summon pig ~ ~ ~ {NoAI:1,Invulnerable:1}
  • set up repeating command block:
  • execute as "AT"p on vehicle at "AT"s rotated as @p rotated ~ 0 run tp "AT"s ^ ^ ^0.3 ~ ~
  • Ride using command: /ride "AT"s mount "AT"e[type=pig,limit=1,sort=nearest]
Note: “AT” is used to replace @ due to forum restrictions.
I tested these replication steps on 2 different AMP servers, as well as a singleplayer world, a LAN server, and a local server. The bug appears on every and only on AMP servers.
Just tested and it doesn’t work in a singleplayer world, doesn’t look to be an AMP issue
Scratch that, tested again in both setups and it works fine
