OS Name/Version: Fedora 42 Server
Product Name/Version: AMP 2.6.5.2 - 20260128.2
Minecraft Neforge jar select version dropdown menu not showing any version
Step 1: Open minecraft instance > manage > configuration > MInecraft > server and start upp
Step 2: Select NeoForge as server type, and Specific version for release stream.
Step 3: NeoForge Version drop down menu stays empty
Updated AMP to most recent version
This is a brand new instance created after update, have tested a new instance with the same results.
def broke. also getting the same thing and deleting the xml does nothing
Luis1
February 9, 2026, 4:06am
3
Can confirm that something is broken, deleting the NeoForgeVersionManifest.xml like suggested in some other topics does not fix the issue.
King
February 9, 2026, 4:41am
4
Someone found a solution on Discord
Issue seem to be from Neoforged itself. Their Naven metadatafile seems to be empty
What works is to delete the current NeoForgeVersionManifest.xml, add an older one, and then reboot the instance.
I cannot attach the file here, but you can find it on Discord in the Minecraft text channel.
Zdyzeus
February 10, 2026, 3:50am
5
is definitely right, I was able to find that file from the discord thread. If you go into your AMP main menu > File browser > Select the instance with the issue > Locate NeoForgeVersionManifest.xml, and copy and replace the content from the the new .xml into the old. I was able to edit the version just fine after this.
I tried to put the file contents in spoilers but it was 25k over the charater limit lol
system
Closed
March 12, 2026, 3:51am
6
