Minecraft - Memory usage isn't accurate
Product AMP ‘Callisto’ v2.5.0.6 (Mainline)
View correct memory usage
This is more of a question than an issue, but I paid for the 8GB plan and the server only says I have two. The memory usage also never changes so I don’t think it’s accurate to begin with. I was wondering if this is just a visual bug and if not can it be fixed, I just want to make sure I’m getting what I paid for.
Sounds like you’re with Hostinger? This is the forum for AMP, if you’ve got any hardware/allocation issues you’ll have to talk to Hostinger’s support.
I’m having the same issue–did you find a solution? Idk why the hostinger customer service tickets send us here…
You could try increasing it under Java and Memory, otherwise it would be some weird issue on Hostinger’s end, not AMP’s.
Aha! That worked, thanks.
