I’m pretty frustrated at this point and am contemplating doing an OS Reinstall
Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
ADSModule requests dependency InstanceManagerPlugin...
24:54:38
Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
ADSModule requests dependency SystemUserManagerPlugin...
Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
24:54:39
Using keypair with fingerprint e63Zkp4eAZA/Kk++cpa/e88Iamo6AN3DKlo6AFy3fEU=
Websockets are enabled.
fatal: detected dubious ownership in repository at 'D:/AMPDatastore/Instances/ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates'
'D:/AMPDatastore/Instances/ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates' is on a file system that doesnot record ownership
To add an exception for this directory, call:
git config --global --add safe.directory D:/AMPDatastore/Instances/ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates
RouterTimer@10Hz with 2 jobs started
Checking for AMP updates...
24:54:40
AMP is up-to-date.
:admin01:01:08
Non-managed instances exist, autoconfigure cannot guarentee that the configuration is valid!
01:01:09
Using cached archive: D:\AMPDatastore\Instances\AMPCache-2404.zip
01:01:35
Waiting for AMP instance to start...
AMP instance Minecraft01 is now running.
01:01:47
Instance Minecraft01 has stopped.
this is about the same thing I’ve seen all day. This started happening after I tried to create a new minecraft instance. It said it needed to update so I let it update everything, and now… nothing works… I’ve gone as far as completely removing all associated folders and AMP entirely… rebooting and then installing it again…
Check the logs of the instances. Likely they need reactivating. For whatever reason the latest update is having issues with keeping licence activations.
I get a similar log when I try to launch minecraft as well…
[04:54:36] [AMPService Info] : Starting AMPService version 2.4.0.4 (Halimede), built 10/09/2022 16:30
[04:54:36] [AMPService Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[04:54:36] [GSMyAdmin Warning] : Current time zone is set to Eastern Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[04:54:36] [AMPService Info] : OS: Windows / x86_64
[04:54:36] [AMPService Info] : CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz (4C/4T)
[04:54:36] [AMPService Info] : AMP Instance ID: cc31267b-6460-4b72-9d80-aa01513293a9
[04:54:37] [GSMyAdmin Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[04:54:37] [GSMyAdmin Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[04:54:37] [GSMyAdmin Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[04:54:37] [GSMyAdmin Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[04:54:37] [GSMyAdmin Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[04:54:37] [GSMyAdmin Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[04:54:37] [GSMyAdmin Info] : ADSModule requests dependency InstanceManagerPlugin...
[04:54:38] [GSMyAdmin Info] : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[04:54:38] [GSMyAdmin Info] : ADSModule requests dependency SystemUserManagerPlugin...
[04:54:38] [GSMyAdmin Info] : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[04:54:38] [GSMyAdmin Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[04:54:38] [ADS Info] : Metrics server started OK on port 12820
[04:54:38] [System Info] : Updating remote source CubeCoders/AMPTemplates
[04:54:38] [System Info] : Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
[04:54:39] [FileManager Notice] : Using keypair with fingerprint e63Zkp4eAZA/Kk++cpa/e88Iamo6AN3DKlo6AFy3fEU=
[04:54:39] [GSMyAdmin Info] : SFTP Server started on 0.0.0.0:2223
[04:54:39] [GSMyAdmin Info] : Websockets are enabled.
[04:54:39] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[04:54:39] [GSMyAdmin Info] : Webserver started on http://0.0.0.0:8080
[04:54:39] [System Info] : Checking for AMP updates...
[04:54:40] [System Info] : AMP is up-to-date.
[05:01:08] [InstanceManager:admin Warning] : Non-managed instances exist, autoconfigure cannot guarentee that the configuration is valid!
[05:01:09] [System:admin Info] : Using cached archive: D:\AMPDatastore\Instances\AMPCache-2404.zip
[05:01:35] [System:admin Info] : Waiting for AMP instance to start...
[05:01:35] [InstanceManager:admin Notice] : AMP instance Minecraft01 is now running.
[05:01:47] [System:admin Activity] : Instance Minecraft01 has stopped.
[05:09:04] [InstanceManager:admin Warning] : Non-managed instances exist, autoconfigure cannot guarentee that the configuration is valid!
[05:09:04] [System:admin Info] : Using cached archive: D:\AMPDatastore\Instances\AMPCache-2404.zip
[05:09:25] [System:admin Info] : Waiting for AMP instance to start...
[05:09:25] [InstanceManager:admin Notice] : AMP instance SevenDays01 is now running.
[05:10:00] [System Activity] : Instance SevenDays01 has stopped.
[05:13:34] [System:admin Info] : Waiting for AMP instance to start...
[05:13:34] [InstanceManager:admin Notice] : AMP instance SevenDays01 is now running.
[05:13:35] [System:admin Activity] : Managed remote instance SevenDays01 at http://127.0.0.1:8082/
[05:13:35] [ADS:admin Activity] : Authentication token for admin requested by ManageInstance on behalf of admin
[05:13:56] [System:Anonymous Error] : Failure to make API call to SevenDays01 (http://127.0.0.1:8082/API/Core/GetAPISpec) - retried 10 times : An error occurred while sending the request.
[05:13:56] [ADS:Anonymous Error] : HttpRequestException
[05:13:56] [ADS:Anonymous Error] : [0] (HttpRequestException) : An error occurred while sending the request.
[05:13:56] [ADS:Anonymous Error] : at ADSModule.WebMethods.<MakeInstanceRequest>()
at ADSModule.WebMethods.<Servers>()
[05:13:56] [ADS:Anonymous Error] : WebException
[05:13:56] [ADS:Anonymous Error] : [1] (WebException) : Unable to connect to the remote server
[05:13:56] [ADS:Anonymous Error] : at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
at Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
[05:13:56] [ADS:Anonymous Error] : SocketException
[05:13:56] [ADS:Anonymous Error] : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8082
[05:13:56] [ADS:Anonymous Error] : at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
at Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
[05:14:01] [System Activity] : Instance SevenDays01 has stopped.
