| Product | AMP ‘Phobos’ v2.6.2.6 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Stopped |
Quite “easy” access during startup
Security Problem Description
Just wanted to find a way to use minecraft forge without plugin and have an animated server icon. Though by doing that I found a way to start a server from the “run.sh” (or “run.bat”) file which could be kinda problematic. It could allow access to part users should’t be allowed to, including the computer itself (yeah … i know it use a container, but their is always a way to).
- Creating a start.jar file (won’t explain how… but easy)
- Editing startup parameters to use this file
- Edit with anything you want “run.sh” (or other similar startup files. I tested on a minecraft container).
- Start the server from AMP
PS : Don’t really know where to put this. So I’ll just post it in Technical Support. Sorry if it’s not the best place.
