Yabdat
22 November 2022 01:19
1
OS Name/Version: Ubuntu 22.04
Product Name/Version: 2.4.0.10
Problem Description: Console command /forge tps not showing up in console.
Step 1 Use /forge tps in console
Step 2 Not showing up in console
Step 3 Check log file, output in log.
Either I’ve done somehting wrong, or there is something wrong…
If you do a /forge tps in the minecraft console of AMP, the output of the command does not show up in the console. It does show up in the log file.
I have tried to change the ‘Supress Garbage’ setting, but no change. Even with restarting AMP in between.
Am I missing something, or is this a bug?
Is that one of the servers that’s compatible with the TPS section of the status page? It’s probably consuming the log line if so.
Yabdat
22 November 2022 01:52
3
Yes, the TPS section of the status page works, so it might be that. But that is kind of a problem, since the command /forge tps show the TPS specifically for each world/dimension in minecraft, and sometimes you need that to figure out what is lagging the server.
I’d suggest installing spark (https://www.curseforge.com/minecraft/mc-mods/spark )
It’s a good profiler and offers a “/spark tps” command
Edit: doesn’t do per dimension readings afaik, that may need to be done in game, or read the latest.log for the output of the /forge tps command
