OS Name/Version:
CentOS 8
AMP Release “Triton”
v2.3.4.2, built 11/07/2022 17:05
After updating to 2.3.4.2, my Minecraft instance will not start. My Satisfactory server starts fine however. When going through the logs, I’m only seeing:
19:25:37 Waiting for AMP instance to start...
19:25:43 Failed to start AMP. Exit code was 1
Instance does not run in a docker container, and is bound to the internal IPv4 of the server (not looback or 0.0.0.0). Please let me know what other logs I can possibly check as I want to be as helpful as possible. Thanks!
Restart AMP
Manually re-installed update via ampinstmgr --nocache ugpradeall
Instance auto-launches (happens when manually launching as well)
Check logs, but they consistently just say exit code 1
So I cannot get into the instance, but when I navigate to File Manager → Instance Name → AMP Logs here are the files:
[00:00:00] [Logger Info] : Rollover from previous log file: AMP_Logs/AMPLOG 2022-07-11 00-00-00.log
[01:51:00] [Core Error] : SocketException
[01:51:00] [Core Error] : [0] (SocketException) : Connection refused
[01:51:00] [Core Error] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
at Net.Sockets.UdpClient.Send (Byte[] dgram, Int32 bytes)
at ModuleShared.MetricsInfoPublisher.ScheduleHandler (Object sender, EventArgs e)
[01:53:00] [Core Error] : SocketException
[01:53:00] [Core Error] : [0] (SocketException) : Connection refused
[01:53:00] [Core Error] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[05:56:00] [Core Info] : Checking for AMP updates...
[05:56:01] [Core Info] : A new update is available!
[11:56:00] [Core Info] : Checking for AMP updates...
[11:56:01] [Core Info] : A new update is available!
Are these the correct logs? This is showing from today so hopefully they are recent. Again I did perform a manual update on AMP and my other instance is working great. Really appreciate your time!
You’re a legend! I’ll respond here once I test later today.
–Update–
Happy to report that this patch fixed my issue I had to manually update the Minecraft instance itself, but after that it’s working great. Appreciate the support and quick turnaround time!
