Minecraft Console not showing old log messages
OS Name/Version: Windows 10 22H2
Product Name/Version: AMP v2.4.4
Problem Description: When opening a new browser window and navigating to the Minecraft server console, there are no messages showing even though the server has been running for some time. I would late to be able to see the previous log events instead of going to file explorer to find the log file, how can I force AMP to load the Full log in the console, and not just the log from that session?
  • Connect to your AMP IP
  • Login and navigate to Minecraft Instance
  • Open Console to an Empty screen
  • Checked AMP settings, could see any settings to affect this
  • Checked AMP files to see if i could extend the time of log or messages to load settings to no avail.
NOTE I know Console Scrollback exists, however i am really asking if there is a way to change it from time, to how many messages, eg: remember the last 500 messages instead of last 60 mins. This would be useful for if a bunch of stuff happens at one time, and then everyone leaves and it’s quiet for an hour. Is this a feature or is there a workaround to make this work?
The console is due to be rebuilt soon so that you can scroll back as far as you like just by scrolling up, similar to Discord etc.
That sounds absolutely awesome, cant wait for it!
