Minecraft - Bungeecord permanently shows Starting
Virtualization ProxmoxLXC
Current State Starting
BungeeCord, shows starting all the time.
Server constantly shows that it is starting, but it runs fine
  • Start the Server
  • Check the console to see if the server is starting
  • Start is OK!
  • Display shows STARTING…
Do you have any plugins installed that might be changing the startup/ready message? Because that’s how AMP detects if the proxy is ready.
Tested it myself in a new instance and it seems to register fine
I’m also obligated to note that BungeeCord is outdated and insecure compared to Velocity.
https://discourse.cubecoders.com/t/minecraft-proxies-and-you/17673
No Plugins installed!
It is a fresh Instance!
Velocity shows running
Bungeecord not, it shows Starting
I only use bungeecord to display a message when the server is offline.
Just checking, but you have the BungeeCord Server Type selected?
No, I mean the Server Type setting in AMP’s interface
I change to Velocity ! Thanks for your help!
