Minecraft Bedrock wrong @latest
OS Name/Version: Ubuntu 24.04.2 LTS
Product Name/Version: AMP 2.6.5.2
Minecraft Bedrock wrong @latest release. It installs Version: 1.21.131.1
but real latest is Version: 1.26.0.2
If I specify Version: 1.26.0.2 manually - it works, but if I switch back to @latest 1.21.131.1 is installed again.
  • Stop Minecraft Bedrock Server
  • Click Update, wait for update to finish
  • Check Version in a Console
  • Manual version switch (works)
  • setting back with “latest“ - installs old version
Your instance config is likely very much out of date
Return to instances, click on the down arrow on the instance tile, check the Deployment Log for any errors
oh… it works… Didn’t know instance can be updated in different ways, thanks!
So update button inside instance updates image only but one on the instances list update instance itself including config?
Explained here: How to update AMP to the latest version - #4
