Problem Description: (Minecraft Bedrock Edition hosted by Hostinger) I updated the “panel” (AMP) to v2.4.4, and now the Minecraft Bedrock Edition instance my kids and I play on is unavailable. I can start the instance, but if I then try to manage it, it will pop up a message stating “The specified instance is not running.” I’m a complete novice at running a server, so I don’t know how to troubleshoot this or what commands I could run in the console to provide more information.
Rebooted the “VPS” - I assume this is the virtual machine itself on which my game server instances reside.
[01:54:11] [Logger Info] : Loading locale data for xx from xx.json...
[01:54:11] [Logger Info] : Starting AMP version 2.4.4.0 (Decadeus), built 17/05/2023 17:54
[01:54:11] [Logger Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[01:54:11] [Logger Info] : Running in a OpenVZ environment.
[01:54:11] [Logger Info] : OS: Linux / x86_64
[01:54:11] [Logger Info] : CPU: Intel(R) Xeon(R) Silver 4214 CPU @ 2.20GHz (2C/2T)
[01:54:11] [Logger Info] : RAM: 2048MB
[01:54:11] [Logger Info] : AMP Instance ID: 2b891d36-fba3-4376-933b-95de7158a432
[01:54:11] [Logger Error] : Unable to load licence for AMP Enterprise - NoMatchingMachineId
[01:54:12] [Logger Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[01:54:12] [Logger Info] : Metrics publishing is enabled at udp://45.90.223.138:12820.
[01:54:12] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[01:54:12] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[01:54:12] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[01:54:12] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[01:54:12] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[01:54:12] [Core Warning] : Branding is enabled but the CustomBranding feature is not available on your current licence.
[01:54:12] [Logger Notice] : Using keypair with fingerprint WZ8LFhAgxhWTQ1qi+uGZgUKrrHzB4tGoigKz4Hi98Yc=
[01:54:12] [Logger Info] : SFTP Server started on 45.90.223.138:2225
[01:54:12] [Logger Error] : No valid AMP licence was found. Please open a shell as the 'amp' user and run `ampinstmgr reactivate Minecraft01` to reactivate this instance.
This is actually something I saw before. I don’t know the credentials for the user account “amp” so I tried it with root and simply get this output/prompt:
[Info] AMP Instance Manager v2.4.0.6 built 30/09/2022 14:13
Please enter value for License Key
Access to AMP has been part of my subscription to this hosting service since day 1; why do I need a license key all of a sudden?
If this is a rented server, you need to contact your hosting provider for support. It’s also worth pointing out that the AMP instance manager is out of date by quite a long way (which implies the OS hasn’t been updated since September last year either)
I updated aptinstmgr to version 2.4.3.6 but that didn’t change the license key thing. I’ll see if I can find an answer at the hosting service. Thank you, Mike.
