Minecraft backups not working
OS Name/Version:Windows 11 Pro
Product Name/Version: 2.6.1.6 - 20250417.2
Problem Description:Automated/Manual backups not working when server is on
[19:45:56] [FileBackup:poopy Error/57] : Unable to add E:\AMPDatastore\Instances\Vanillaserver01\Minecraft\world\region\r.-1.-1.mca to backup archive. Failing backup...
[19:45:56] [Core:poopy Debug/57]  : IOException
[19:45:56] [Core:poopy Debug/57]  : [0] (IOException) : The process cannot access the file 'E:\AMPDatastore\Instances\Vanillaserver01\Minecraft\world\region\r.-1.-1.mca' because it is being used by another process.
[19:45:56] [Core:poopy Debug/57]  :    at Microsoft.Platform.SafeHandles.SafeFileHandle.CreateFile(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options)
   at Microsoft.Platform.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, Nullable`1 unixCreateMode)
   at IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, Nullable`1 unixCreateMode)
   at IO.FileInfo.OpenRead()
   at LocalFileBackupPlugin.BackupProvider.DoTakeBackup(BackupManifest manifest, RunningTask task, Boolean local, Boolean s3)
[19:45:56] [FileBackup:poopy Error/57] : Error writing backup: System.IO.IOException: The process cannot access the file 'E:\AMPDatastore\Instances\Vanillaserver01\Backups\20250423-194554-c80eb354f6f24894b61c6e82d7d2f115.zip' because it is being used by another process.
   at System.IO.FileSystem.DeleteFile(String fullPath)
  • Schedule Backup from a trigger
  • Take manual backup
  • Stopping server allows manual backup to occur
Changed backup size limits and settings
Changed auto backup times
Changed backup values in scheduler
Restarted Server, Amp, and machine
Changed logging level to 0 for debug
Captured full backup error message
Unable to complete backups while server is active, did work in the past
A dev is currently looking things over, thanks for the logs!
