Minecraft - A Mod that i´m trying to use i´snt working
Product AMP ‘Phobos’ v2.6.2.2 (Mainline)
Run Mods
A Mod that im trying to use isnt working and i cant figure out which mod it is because its only telling me the code and not which mod
it says in the Console: Exception in thread “main” java.lang.IllegalAccessError: class cpw.mods.modlauncher.SecureJarHandler (in unnamed module @0x5b8bc155) cannot access class sun.security.util.ManifestEntryVerifier (in module java.base) because module java.base does not export sun.security.util to unnamed module @0x5b8bc155
and: at cpw.mods.modlauncher.api.LamdbaExceptionUtils.uncheck(LamdbaExceptionUtils.java:95)
  • Made a Mods folder
  • Put the zip file with the mods in it
  • started server
You can always go back to the basics and disable a chunk of mods and restart. If the server comes up, it is one of those, if not it is not in the group you disabled. Divide and find. Disable another batch of Mods and restart. Check results. Narrow down the group that has the failed mod until you find the issue. If it was me, I would backup all your files first, find the bad mod, restore your backup and disable the offending mod. Then I would research the mod, talk to the developer and see if there is a fix.
