Migrating Instance to datastore on same machine on Windows
OS Name/Version: WIndows 11 Professional 25H2
Product Name/Version: AMP 2.6.5 - 20260114.3
Hello, I’m currently trying to migrate an instance from one drive to another on the same system. I am on Windows 11 Professional, and the currently available guides I see all refer to various linux distros. I’m wondering if anyone has suggestions on the best way to migrate my instances without data loss, or a step by step guide for migrating a windows instance. Thanks!
Steps to reproduce: N/A
Actions taken to resolve so far: Currently none.
https://discourse.cubecoders.com/t/migrate-instance-to-new-datastore/25340
The steps are nearly identical, just using the Windows file paths.
If you don’t use a tool like rsync you’ll just need to run ampinstmgr fixperms in an Adminstrator CMD prompt to fix file permissions.
Ah, got it. Thank you for the clarification! Very much appreciated as I didn’t want to potentially mess up anything.
