MC instance not starting after update from 2.4.4 to 2.4.6.4
OS Name/Version:
Windows 10 Pro / 22H2
Instance ID │ 0eeaa3aa-ecde-4d65-8f73-08a0bd33dbfa
Module │ Minecraft
Instance Name │ ATM8Server01
Friendly Name │ ATM8Server
URL │ http://127.0.0.1:8086/
Running │ No
Service Instance │ No
AMP Version │ 2.4.6.4
Release Stream │ Mainline
Data Path │ C:\AMPDatastore\Instances\ATM8Server01
Server produces “this instace is not running error when i try to open it”
Says AMP not updated correctly. in log
All other instances on the ADS are running fine tho MC is tho only one not running the generic module. apart from ADS
[13:51:39] [Program Info]         : Starting AMP version 2.4.6.4 (Decadeus), built 07/09/2023 18:02
[13:51:39] [Program Info]         : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[13:51:39] [Core Warning]         : Current time zone is set to Västeuropa, normaltid - It is recommended you switch to UTC+0 to avoid time-zone related issues
[13:51:39] [Program Info]         : OS: Windows / x86_64
[13:51:39] [Program Info]         : CPU: Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz (18C/36T)
[13:51:39] [Program Info]         : RAM: 163744MB
[13:51:39] [Program Info]         : AMP Instance ID: 0eeaa3aa-ecde-4d65-8f73-08a0bd33dbfa
[13:51:40] [Loader Info]          : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[13:51:40] [Core Info]            : Metrics publishing is enabled at udp://localhost:12820.
[13:51:40] [Loader Info]          : Loaded FileManagerPlugin by CubeCoders Limited
[13:51:40] [Loader Info]          : Loaded EmailSenderPlugin by CubeCoders Limited
[13:51:40] [Loader Info]          : Loaded WebRequestPlugin by CubeCoders Limited
[13:51:40] [Loader Info]          : Loaded LocalFileBackupPlugin by CubeCoders Limited
[13:51:40] [Loader Info]          : Loaded CommonCorePlugin by CubeCoders Limited
[13:51:40] [Core Error]           : CryptographicException
[13:51:40] [Core Error]           : [0] (CryptographicException) : Det går inte att hitta det begärda objektet.
[13:51:40] [Core Error]           :    at Security.Cryptography.CryptographicException.ThrowCryptographicException(Int32 hr)
   at Security.Cryptography.X509Certificates.X509Utils._QueryCertFileType(String fileName)
   at Security.Cryptography.X509Certificates.X509Certificate.LoadCertificateFromFile(String fileName, Object password, X509KeyStorageFlags keyStorageFlags)
   at GSMyAdmin.SignatureVerification.Verify_Windows(String Filename)
[13:51:41] [Settings Warning]     : Unable to set field value for node: DiscordBotSettings.BotRefreshInterval to 30 - Method not found: 'Void ModuleShared.WebSetting..ctor(System.String, System.String, Boolean, System.String, System.String, System.String, Boolean, System.String, System.String)'.
[13:51:41] [Loader Info]          : Loaded DiscordBotPlugin by CubeCoders Limited
[13:51:41] [Scheduler Warning]    : Schedule trigger 6ded3036-4bf2-4336-ada2-f1a9507e31d9 has a mismatched ID!
[13:51:41] [Scheduler Warning]    : Schedule trigger fb9d2669-6a6b-4c8e-9d72-47d3bedd4455 has a mismatched ID!
[13:51:41] [Core Info]            : Licence Present: AMP Network Standard Edition
[13:51:41] [Core Info]            : Licence Present: AMP Developer Edition
[13:51:41] [FileManager Notice]   : Using keypair with fingerprint wU9xhA13bNjp4UgkJWn9FkuslKQ9vFzT5PS8P8aQjm4=
[13:51:41] [FileManager Info]     : SFTP Server started on 192.168.50.45:2229
[13:51:41] [DiscordBot Info]      : Discord Bot Activated
[13:51:41] [DiscordBot Info]      : 15:51:41 Discord     Discord.Net v1.0.0 (API v10)
[13:51:41] [DiscordBot Info]      : 15:51:41 Gateway     Connecting
[13:51:41] [Webserver Info]       : Websockets are enabled.
[13:51:41] [ErrorReporter Error]  : AMP not updated correctly.
[13:51:41] [ErrorReporter Error]  : [Error] --- Begin Exception Data ---
[Error] OS: Windows (x86_64/None)
[Error] Module: MinecraftModule, Version: AMP 2.4.6.4
[Error] Instance ID: 0eeaa3aa-ecde-4d65-8f73-08a0bd33dbfa
[Error] MissingMethodException
[Error] [0] (MissingMethodException) : Method not found: 'Void ModuleShared.WebSetting..ctor(System.String, System.String, Boolean, System.String, System.String, System.String, Boolean, System.String, System.String)'.
[Error]    at ModuleHandle.ResolveMethod(RuntimeModule module, Int32 methodToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount)
   at ModuleHandle.ResolveMethodHandleInternalCore(RuntimeModule module, Int32 methodToken, IntPtr[] typeInstantiationContext, Int32 typeInstCount, IntPtr[] methodInstantiationContext, Int32 methodInstCount)
   at ModuleHandle.ResolveMethodHandleInternal(RuntimeModule module, Int32 methodToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)
   at Attribute.GetCustomAttributes(MemberInfo element, Type type, Boolean inherit)
   at Attribute.GetCustomAttribute(MemberInfo element, Type attributeType, Boolean inherit)
   at ModuleShared.SettingSectionStore.GetFieldsFromTags(Boolean withTagsOnly)
   at GSMyAdmin.WebServer.WebMethods.BuildSettingSpec()
   at GSMyAdmin.WebServer.APIService.AddCoreModule(HttpBackend backend)
   at GSMyAdmin.WebServer.LocalWebServer.Start()
   at GSMyAdmin.Core.Run()
   at GSMyAdmin.Program.Main()
[Warning] Unsigned plugins are loaded: DiscordBotPlugin - error report will not be submitted.
[Warning] Last error was raised less than 60 minutes ago, error report will not be submitted.
[13:51:41] [ErrorReporter Info]   : ####################################
[13:51:41] [ErrorReporter Info]   : #         Self Diagnostics         #
[13:51:41] [ErrorReporter Info]   : This exception likely means that AMP was not updated correctly. Please re-update this instance.
[13:51:41] [ErrorReporter Info]   : The exception message was: Method not found: 'Void ModuleShared.WebSetting..ctor(System.String, System.String, Boolean, System.String, System.String, System.String, Boolean, System.String, System.String)'.
[13:51:43] [DiscordBot Info]      : 15:51:43 Gateway     Connected
[13:51:43] [DiscordBot Info]      : Base command for bot: minecraftserver
Update MC instance from 2.4.4 → 2.4.6.4 and try to launch instance.
I have followed these steps in the 2.4.5 release notes and in the windows troubleshooting thread and no luck
I have also tried to reactivate the instace and repair amp install and no luck.
You’ve got unsigned 3rd-party plugins loaded that probably need to be rebuilt for the latest version of AMP.
Thanks!
I missed that completely as it said it loaded.
Its working fine now! :grinning:
